Its started :)
W
walrus
Maine
Understood. I have supplemental heat. And cracked the code on my Insullation. Going spray foam. Best for quanset huts.
Spray foam will make that a very tight building, should be easy to heat and comfortable to work in
W
walrus
Maine
I have been thinking about a solar collector again and I thought you had done one, how is it working? Been a while since you updated!
I love it, shop stays above 45 or so all winter with no other heat going. It's generally around 50. Stoking the woodstove gets it warm real quick if I want to go there and work. I've done nothing to it since I got it going except I went with a new controller. My shop was built to take advantage of solar though. Floor is insulated, edge of slab insulated. Walls and ceiling 2inches of foam plus cellulose in attic, fiber in walls. The building is tight other than 10 by 10 door. Best door I could find plus weatherstripping.
Strouty
Southern Maine
I have been toying with it for a while, but mine will probably just be air. I was thinking of having it heat water so it stores the heat after the sun goes down, but not sure the best approach. My floor is not insulated and my doors are the worst ones I could find.
W
walrus
Maine
I wouldn't waste my time with air.
W
walrus
Maine
Would you just make radiators then?
To move air takes energy, to move an equivalent amount of energy in water takes way less energy. I'd heat a tank of water and then use that water for heat. But it takes real hot water to make a baseboard effective. That's way my system works so well. 80 degree water heats my floor fine, won't do **** in a baseboard . I'd recommend a website called builditsolar.com
W
walrus
Maine
Cold snap is testing my premise that my solar radiant floor will keep my shop above freezing. It was 40 in there yesterday, no back up heat for couple of weeks. Thats the lowest temp I've seen in there. It generally stays around 50 but we haven't had a cold snap like this in 40 years according to weather guessers.
I was in there around 10.30 yesterday morning and collector temp was 32. The sun was shining. No help there.
dwysywd
SE Michigan - Romeo area
Keep us posted. I thought you said you had a wood stove? Or did you mean no other way to heat the floor? What about a small 10gal 110v as a backup when it gets stupid cold.
Sent from my bag phone
W
walrus
Maine
I do have woodstove, I can heat it, just curious as to how low it will go. 37 when I went out there this morning.
2011laramie
Central Alberta
How cold is this cold snap your dealing with? Its minus 28C and minus 40C in the wind in alberta right now.
If your having problems in the US i doubt mine would work up here, once its built.
W
walrus
Maine
It's below zero f, no wind today. Collector temps in 80s right now.
High noon,3f out, collector temp just over 100. Going into floor at around 50.
Strouty
Southern Maine
That is awesome that things are staying that warm with no backup heat source being used. I am paying about $25 a day right now to keep my shop at 40. Someday I will build a new shop and I can do all the fancy things to save money, but right now it is just not in the cards.
86turbodsl
Man I would love to try this out. I am redoing my floor plumbing maybe it's time to add a couple auto valves for future...
Sent from my SM-N910T using Tapatalk
W
walrus
Maine
I'm on the coast of Maine this is the first time I've seen temps this low in shop. Shop is built to heat easily. You would be similar to northern Maine. I doubt it works up there but it would help.
Put some junk wood in stove and got it up to 50, filled it with oak as I want to be out there tomorrow. I will fill it again later. I'd guess 60 by morning.
W
walrus
Maine
Can you post a few pics of your setup inside with respect to controls, manifolds etc.? Don't worry about aesthetics...just looking for simplicity.
Missed this, sorry about that
16270b80bbbbcf402d41c1137f39ce77.jpg5ed2741826b711ac18a675ae885c3911.jpgdcb4f828ece62b30c261c204b86779b8.jpg
Denwood
Thunder Bay, Ontario, Canada
Looked up this thread and realised I had missed your update last year with the system pics.
How does the Stiebel controller work. Is that a LAN cable I see in pic1...that goes to the controller?
W
walrus
Maine
No network connection. controller is programmable for delta T on and delta T off. I have it set for 10 degrees higher than slab on and when it gets to 4 degrees higher off
35k0
Minnesota
Wow, what an awesome build.
This makes me want to sell my boiler panel and build this solar system out. I hate paying the electric bill when the shop floor gets turned on Fall-Spring.
Maybe I could keep the system I have, but turn the heating elements off?
W
walrus
Maine
Couple things about the build, it built to use solar as a heat source. It’s tight and insulated to take advantage of what little heat the sun generates in Maine in the winter. Why it works is, the floor s generally at approx 50 degrees or less. That means collector temps in the 60s puts heat in the floor. 60s is easy to get. The sun is higher now so temps much Higher than that are easy now. Sometimes as high as 110f . That’s not the fluid temp as it’s generally a few degrees higher than floor temp when solar is running. If I did it again I would have covered the whole south side of wall it’s collector.
