J H Williams vintage hand tools
wrenchguy
NW Indiana
Depending on condition there is a $100 REWARD FOR THIS WRENCH. It has to match the sizes listed for the NO.1. It has to show the "diamond w" or "oval" logo along with a stamped or embossed "1". thx.w2.jpgw1.jpg
bonneyman
Desert SW
What do you use for the pin holes on the face by the anvil? A baby face spanner?
That'd work. I use a pin spanner I have for bicycle bearings. Has pretty small tips.
Like this:
To get the pawl and spring out, remove the press fit pin selector with a vise grip. Then you can unscrew the bolt and get to the pawl parts. The pawl is held in by a floating pin, hard to get out if it's full of old grease. But if you soak it long enough, a strong magnet should ****** that retention pin out of there. Hope this helps!
1937 Jennison Hardware Co. catalog J.H. Williams ad pp 318
1937 Jennison Hardware Co. catalog J.H. Williams ad pp 319
1937 Jennison Hardware Co. catalog J.H. Williams ad pp 320
1937 Jennison Hardware Co. catalog J.H. Williams ad pp 321
1937 Jennison Hardware Co. catalog J.H. Williams ad pp 322
mritchie77
Cottonwood Shores, TX
Definitely on the "newer" side of vintage but I figured this might be from the late 70's to mid-80's? Almost complete 3/8 metric set I picked up with weekend. The sockets are double stamped Williams and Vulcan, but the ratchet and short extension are only marked Williams.
Looks to be missing a 3" extension and either a universal joint or spark plug socket in the middle. I haven't been able to find any modern or vintage advertisement or catalog coverage that shows the MSB-13 set.
Provincial
Near Salem, OR
I saw a combination wrench at an estate sale today. Obviously a Craftsman =V=, but when I turned it over, it said it was a Williams! I've never seen one like that before.
PSCo1867
PA
I recently stumbled onto a 1979 J.H. Williams catalog, and found your MSB-13 set. It looks like your guess for the missing middle item is correct (universal joint).
Now, to figure out how upload this catalog for all to see.
PSCo1867
PA
misterbill
Diving down another rabbit hole... since I now know what goes into the Williams TB-4A box I went rummaging through my stash and (disappointingly) have 5 of the 60 pieces. I know that the wrenches would be of the underline style and the sockets would be the two band variety.
Looks kind of sparse! :D
Bill
mritchie77
Didn't get to thank you yet for following up with me on this one. Not many do! Actually saved me a bit as I was thinking the universal would be the older B-140 but it's actually a B-140A
Millerfish
Got these Williams items in a lot recently. What era are they from?
I think anything diamond stamp is a little bit older than the others. May be era mixed pieces there but who knows about transitioning.
Since Williams stuff looks very similar for a long time, I'm just guessing that these could be a mix of 50's and later.
Coincidence I was just replying to member Millerfish‘s post. The other day I ran across this tiny pin spanner in my things and took a few photos.
Made by Williams, and branded for Miller Tool & Mfg. Co. Auto Service Tools. Miller is well known as the tool supplier for Plymouth, Dodge, Chrysler.
74a16cf3-f44a-4a6c-ae75-ed1c8d34baa8-jpeg.1834801
Appears to be a stock 453 spanner
Cover of 1938 catalog at archive.org showing full logo.0C43EC89-262A-4547-94C8-5C0C2DEF9122.jpeg
Similar looking spanner for power steering service, 1956 catalog at archive.org.
JohnDeere
NE Ohio
My williams 3/8 WSB-20 metric “set”. I have given up on finding sockets to fill the holes. Found an old school snap-on 10mm for the set. I also have my sae williams sockets in here.EB5C5D1C-FB04-4643-9428-E1BF8996D885.jpeg1F2F404E-C62A-4F13-9875-483BC849E088.jpeg
MisterEd
Florida
J.H. Williams NM-20A 1/4 Drive Sliding T-Handle and Six NM-series Sockets.
12-Point Sockets: NM-1214, 7/16; NM-1212, 3/8 and NM-1211, 11/32
Hexagon Sockets: NM-609, 9/32; NM-608, 1/4 and NM-606, 3/16
Fred Knox
Nor Cal
It took me awhile, but I finally filled out my Williams "Superjustable" wrench set, with only the 4" having the raised ring around the hanging hole. I finally picked up the 12" this weekend, along with the W-diamond K-2 roll of small DOE wrenches (7/32" x 13/64", 1/4" x 15/64", 5/16" x 1/4", 11/32" x 9/32", 3/8" x 5/16").
outofbounds
Found this otherwise Run-of the-Mill Williams 729 the other day. What I didn’t notice until closer inspection at home was the beautiful Pierce Arrow logo inscription on the shank. Tool kit wrench? Anyone seen this or different sizes similarly marked?
