OldeTimeEtc
Starting assembly - before any grease is applied I recommend a dry run assembly of the jaws and nut unit. So first order of business is to note what hole position each jaw sits in. First check out the illustration I DLed from Jacobs website. You will notice that although each jaw looks the same there is a small difference at the end of the threads on the business side of the jaws. If you look at the jaws from their side you will see what the illustration is showing..somewhat. I found it doesn't look quite exactly like the drawing BUT...if you will not the spaces are get wider on each jaw.....starting from 1 which is the narrowest to 3 which is the widest. Take a piece of paper and number it like I did.......makes it easier to remember which is which once you identify each one....or simply number them with a sharpie.
