Been following your build it's turned out great!
Couple questions did you use receiver tubing for the receiver hitch? Or just normal tubing with the weld seam still inside?
Any reason why you didn't turn the angle iron on the bottom around so that it cradles the tool box?
Reason I ask is it looks a lot easier to slide the boxes into position like you did then having to drop them in. Once they are loaded up I doubt they will move but do you plan to secure them in anyway?
Also very jealous of those tents!
Can you explode from too much jealousy ?Can you explode from too much jealousy ?
Going to be a beautiful thing!
Sweet.
Have a good one, Gerard
Love the build, really nice work.
great build, great planning. i am working on something similar, a bit more modular with 2 HF 44" boxes. plenty of ideas on this site.
more pics once completed please.
Well done...I've got a MB 1100 I bought new in 92 that's pristine...I have to admit you've got me thinking. ThanksEnjoy!
Central Ohio ? If you suggested that Chad stop by, you must be close to him. Where do you buy your steel at ?
Bench looks great and the shine of that top is awesome.
Thanks! I'm in Mt Vernon and purchased my steel from Custom Cutters here locally.
Have a good steel source up your way? I work at Bucyrus Hospital every now and then.
No not really. I usualy pick up what I need from a local guy(Pifer's). It can be slim pickings sometimes. There is another place that told me they would order in stock if I wanted it, I'd have to take the entire 20' stick though. It's a small 2 man fab shop that is hidden, Spec Tech. I'd have no problem buying a 20" piece as they woul cut it down (8'/12') for easy transportation and storage.
My biggest issue is the storage of long pieces and no wall space. I think I have figured out a spot to make some storage though, on my I-beam.
EDIT; I noticed the EAC shirt, that you/your business ?
Http://www.EACconcepts.com
Hydrographics, Cerakote, DuraCoat
