Jet JMD-18 Mill Drill
kyrbz
midwest US
Most of these types of mill/drills are manufactured by Rong Fu. There are also some lesser quality Rong Fu clones. You can get the exact same mill/drill as the Jet branded as a Grizzly for $1295.00. Generally they're pretty robust machines for the money.
http://www.grizzly.com/products/Drill-Mill-with-Stand-29-inch-x-8-inch-Table/G0705
I tend to like Grizzly over Jet on comparable machines because Grizzly is way better about getting replacement parts if they're needed.
-BZ
Provincial
Near Salem, OR
I have done some pretty serious jobs on my Ru Fong mill drill. They have their limitations, but can do a lot of work. They are limited in spindle nose to table distance and any vertical travel has do be done with the quill after setting the head for height.
In my estimation, 50% of new price for the mill and tooling is maximum. At two grand, you are getting into Bridgeport (clone) territory, and it is well worth a few more bucks to get the more versatile machine.
rsanter
visalia ca
As said you can get the same thing under different names for less.
To me it looks like $1000 tops assuming it has a bunch or tooling and is in near new shape
Bob
nmk_61802
Central IL
I picked up a JMD-18 for less that 600 last year off CL and thought that was high, however it had no tooling or stand.
The major limitation with the JMD-18 is the round column. If you need to reset during milling you need to recenter the quill on the stock.
rodm1
I have the Rong Fu they are ok but really just a toy. I full size Bridgeport would be much better.
zkling
As others have stated, hold out for a "real" / larger mill such as a Bridgeport or the like. Avoid the round column mills for a general purpose mill. Especially at that price. If space is really at a premium, look for one of the smaller clausing 8520 mills.
