jet/wilton 4002 belt sander
nerraw117
Concord, NC
I picked up a jet 4002 for next to nothing awhile back. seems to work descent. it makes alot of noise when its running and come to find out the v-belt is trashed. cheapest I can find one is 30 dollars. anyone got any better insite? it is a very short v-belt. think pull off and take to napa?
this is the sander in question.
https://www.amazon.com/dp/B00381YI9M/?tag=atomicindus08-20
this is the belt in question
https://www.ereplacementparts.com/vbelt-p-445038.html?osCsid=pscm6t93rlpmle4sr1u6j035m7
Provincial
Near Salem, OR
You will need to determine what belt design that is, as well as the length. The M-19 designation in the photo is probably not the real number, just a stock photo of a belt. Are there any markings on your belt?
It may be a metric belt. They are available, but not as common as standard belts. There may be a chance that an American A belt (.500 x .3125) will fit, since a 13mm belt (.5118 x .3937) is almost exactly 1/2" wide.
Have you tried a local store that carries Wilton/Jet? I have had good luck finding parts this way.
tool_scrounge
Southern California
Take to your auto parts store. Best to go to an independent store. Otherwise be prepared for getting asked what year/make/model/displacement/floor mat color car it came off of. Then get puzzled looks with no resulting solution.
bubinga
LMAO [emoji23] [emoji23] [emoji23] [emoji23]
0P what did you come up with?
Sent from my MotoG3 using Tapatalk
