Jib Crane Install
AlexHamm
Lowell, MI
I just found this Jib Crane made by manning maxwell and moore. its really cool. the company was founded in 1905 and made supplies for the railroad industry according to wiki. Does anyone have any experience with these. The boom is 15 feet. The I beam is 10 inch by 4.5 I am wondering what my max load is @15ft and how much concrete I need to be safe. I want to use it to lift diesel engines and transmissions from pickup trucks after we have the cab off. I would say no more than 1 ton max. Thanks -Alex
zkdiesel
chicagoland cornfields
Awesome thanks, does this one look like it should handle a ton?
Should have a rating tag
Your base will be your factor to consider
Also doesn’t work worth a Fawk for pulling engines with cabs off as you have to roll truck foreword to then lift them out. I use my cherry picker or skidsteer then for that
If you don’t move the chassis you can set can back down with no line up issues
As soon as you move chassis getting can back on straight *****. Go jacks are your friend
Steve from Socal
Hutchinson Ks.
I have three jib cranes with 10" I beam booms, they have tension straps and a brace. They are 1000 pound capacity. They are a little longer than your jib about 20' mine are sistered to columns in my shop. I have lifted heavy tooling and fixtures close to the columns without issue maybe 12~1400 pounds
Here is a pic of one over my lathes.
Steve
