Joining rafter vents for 4' space
493 scamp
Kirkwood,Illinois
My trusses are 48" spacing and I want to use ADO Durovent which is 23.5" wide. What do you guys use to attach to trusses and to each other to span the 48"? I want to use blow in insulation in my 32x40 polebarn.
larry4406
Northern Virginia
I would put in a dummy "rafter" and head it off between the trusses far enough back so you can use the battle and be above blow in depth.
Chris705
The Finger Lakes of NY
wouldn't you staple two of them side by side and stapple to the roof purlins? then seal off space at soffit/wall/ceiling junction to prevent cellulose from blocking vent ends...
