Jointer recommendations
lardy1
Can I get into anything I'm not going to regret buying for five to seven hundred? I'm just a serious hobbyist getting on in age. I've had and used ****** ones and I'll make a sled for my planer rather than fighting that frustration.
Anything you might recommend, and why?
TIA
loganb
Omaha, NE
500 to 700 should be able to get you a used Delta or older Powermatic 6" or a newer used Jet/Grizzly or similar 6 or 8". I gave 700 or 750 dor a Delta DJ20 8" so the budget is very reasonable for used machine as long as you're not looking for fully restored
That budget will do here, an 8" Rockwell was under that. Only thing above was a Powermatic with a helical head.
Or get a Stanley #7 and a workout.
L
lardy1
I prefer new. If I stumbled on the right deal I would not be opposed to used but I live out in the sticks and there isn't much of a used market.
tarmy
Nor Cal
If you weren’t so far away I would make you a great deal on this one. I just don’t use it anymore. I made a couple pieces of furniture with it and that was it. Powermatic.IMG_3091.jpegIMG_3090.jpegIMG_3089.jpeg
Stobal
Honestly you are better off with a sled and a jig for your table saw for that budget if you can’t find a used one. 6” will severely limit what you can do and the models available new at that price point leave a lot to be desired. Don’t reject used grizzly’s based on fear of usability. They can be tweaked to work adequately and are good machines. My suggestion is to keep a look out for a used grizzly 8” parallelogram style. Other than foot print it’s a perfectly capable tool with few negatives….other than foot print. You actually see a number of them come up for sale because they do take up a lot of shop space.
