Junction box
Dspurlo81
I'm running 4/0 aluminum wire to my shop. I'm wanting to terminate it outside then run copper inside. Is there a junction box or is this even feasible?
D
Dspurlo81
The box will be 20ft from entry. Does someone make a outdoor junction box?
D
Dspurlo81
They have terminals inside that will work with 4/0?
unsinkable
New England
There are no terminals in a junction box. Drill, or knock out holes for proper size connectors to hold conductors.
You need to use a burndy (split bolt connector) or a 2 hole lug. Thin coat of noalox on each conductor, join them together with chosen lug, then rubber and vinyl tape over.
Cheers !
Charles (in GA)
50 mi south of Atlanta
Joining AL to CU will require something other than split bolts I think. You will need a rated connector such as Polaris connectors.
Still lost as to why you just don't run conduit (depending on the wire/cable being used) and just carry the wire to the panel. Adding a splice is just adding to the future failure list, and for what a junction and Polaris connectors will cost, you probably can buy the conduit.
Sounds like you are rather set on the copper inside however.
Charles
