niferous
I have a fairly small Craftsman air compressor that struggles just running a 1/2" impact gun. So much so that I don't really run it that often. I think this should be able to run just about any 1/2" or 3/4" impact tool I would use. Maybe even two at the same time. But I've never gotten too into air compressors so any input there would be helpful. The data plate says it is 15 CFM and 175 PSI.
I plan on running lines around my garage and also building a sound enclosure around it to keep my neighbors happy. Is steel pipe the best thing to run for permanent air lines? I have some 1" galvanized pipe and I also have some 250 psi air hose at my shop I could use as well. My plan is to run lines around my attic and then have a few outlets with some ball valves that can be hooked up to as needed.
Here are some photos:
weird
