KD Kulp-Dellinger Tools.
...probably made by K-D.
Definitively, without a doubt. Everything about them, including the model numbers.
...these particular ones do not have a hex opening that goes all the way through, but have a stop lip on them.
Like the in-house K-D models. Ratcheting both directions, with the switch, there's no need to use them flipped over.
...and a K-D document.
Is that your label or purloined from the web?
How am I just finding this thread after all these years?
Not sure, it's periodically active, but as a helpful hint, note that if want to see all major GJ Vintage Forum threads at once, whether they are on page 1 or currently inactive, consult the A-Z Index of Threads in the Sticky at the top of the forum.
Eric Brown
All these pictures are off the web. If any objections will remove.
Eric Brown
Oh no, I do it all the time. Public domain. It's the lifeblood of our research. I was just wondering if you owned the label (and could be talked out of it! :))
Unfortunately I don't see it anymore. It might have been bought by somebody already. If I had it I would have given it to you. Sorry.
454 K-D Distributor Tool for General Motors V8 engines 1958-1974
283 K-D Brake Bleeder Wrench 5/16" x 3/8"
297 K-D Brake Shoe Spring Retaining Tool for Comet, Falcon, Valiant, Dart
3083 K-D Swivel Oil Filter Wrench 2-7/8" - 3-1/4"
MisterEd
Florida
K-D Manufacturing Co., 428 Hose Clamp Pliers
MisterEd
Florida
K-D Manufacturing Co., 2149 Brake Bleeder Wrench
Leviton
Oregon
I found this non-standard ratcheting wrench - it only has one opening (1/2" 6-point). It is completely unmarked - not even a size is indicated. It is cadmium plated.
I did a photo overlay and, other than having only a single opening, it exactly matches a K-D #63, even the rivet locations match. The 1961 K-D catalog mentions that their #63 was cadmium coated.
I'm guessing this wrench has to be K-D made? Maybe a contract special? Any thoughts?
(6.55" overall length - shank thickness is 5/16” - 15 tooth.)
@Private Lugnutz appears to have a similar one (albeit with a bend) in a group photo he posted on the first page of this thread...
Keeping my promise with this slightly older group shot...
Eric Brown
I've seen similar used on machinery, sometimes even bolted on. Can't remember what machines though.
Almost certainly a K-D and almost certainly made with the same tooling they used to make a No. 63. It's not unfinished, I don't think, in the sense of it intending to be a No. 63 and they just never completed the 9/16" end. Those shims look purposefully in place there instead of a ratcheting gear.
Thanks for the prompt. I guess I never followed up on that!
Mine is a No. 72. One could argue the bend was shop made. If so, it was very well done. Given the bend and the odd empty end (no gear, no shims, no nothing), I am inclined to think it was a special and factory made. For what, I don't know.
Here's another group shot. That's a No. 20 set (containing No. 21 through No. 24, 3/8" to 9/16"), one orphan shy of another pouchless set to the left, the aforementioned No. 72, a No. 61 and No. 62 from the 6X series (five (5) wrenches, 10 sizes from 1/4" to 7/8"), and a No. 27, which came in a pouch with four (4) double-sided screwdriver and hex bits.
I was never able to find a K-D ratcheting box end wrench with a model No. 72, or any other number, bend or no bend, in any K-D catalog available on IA/ITCL between the 30's and the 70's. They introduced the No. 20 set in 1942, the No. 27 set in 1950, and the No. 6X set in 1959. They went to metric in 1973 and by 1980 had dropped all ratcheting box end wrenches with imperial sizes.
Ayrhead
Ontario
K-D Muffler Tube Pipe Expander. # 2269. Two Other Expanders as well. One no name but made in USA. The other a very old one… SCF is on the top of it…
Leviton
Oregon
Found a pair of K-D battery pliers. They are not the prettiest, but I could not find this version of the 203 in any of their catalogs. I'm not sure what the finish is. Although it is hard to see in the photo, the appearance is like someone painted them with aluminum silver colored spray paint and then polished that - or if you brought a cadmium finish to a high polish and then clear coated it. In contrast to any of the 203 versions in the catalogs, these have very rounded edges.
Markings:
K-D No. 203
Made In U.S.A.
X-X 12
X-X 3
They have a threaded pivot pin.
There were plastic-covered handle versions of the 203 in the 1969 and 1973 catalogs but, even besides the handle, they looked slightly different than mine (i.e. nicer plating and slightly longer nose).
In the 1992 catalog, the 203 was a TOTALLY different design.
Did not find a “203” in any other online K-D catalogs.
In the 1973 catalog, the 203 was referred to as a "Battery Nut Plier".
