Keeping your compressor charged?
99LeCouch
Rochester, NY
For how infrequently mine gets used, it gets drained, unplugged, and put away at the end of its use. It might go a few weeks at a time without being used.
mg283680
Not clever, but my 80g Saylor Beale has a ball valve on the bottom I open to let the water out and remains full. Air all the time, but there's a ball valve at the tank and a switch to interupt the pressure switch when I'm not there.
Having air is another utility.
sam.coll
Melbourne, Australia
I have my compressor in a small shed behind my garage so have an isolation switch mounted near the entry door for the compressor circuit, I have a 25W light bulb connected on the load side of the switch to remind me to turn it off when I leave the shop. When I get around to properly running black iron pipe thru the shop I will probably install a solenoid valve on the tank outlet powered by compressor circuit so one switch to isolate power and air.
firworks
IL
Not including other reasons, my compressor will leak down enough in 5 minutes to kick back on. However, since it also has a problem with the unloader it really means you turn it on. It kicks off. 5 minutes later it tries to turn back on Buzzes loudly and then trips. :) Hence why I've been posting in the California Air Tools threads. I got it for free but my compressor is quite a POS.
RAYJAY
UNION DALE PA
Bc EVERY industrial compressor company suggests draining them daily as PMCS, bc I only need air a few times per week, bc shutting machines off when not in use is industrial safety 101.....
thats what they make a auto drain for.......
mine drains twice a day, and it on 24 /7 full charge just turn off the ball valve at tank
MikeF2316
Thornhill, ON
I unplug and close the valve when not using mine. I can go for weeks without needing compressed air. But I take it as a personal failure if the tank is not at the same pressure I left it at even 2 weeks later. :lol:
