Strouty
Wait, park a car in the garage, you mean one that runs and drives? I don’t understand this concept.
BF, while it's empty, you might want to insulate the walls and ceiling in the garage. Once the garage is insulated you can maintain a comfortable working temperature with a relatively small heater in the winter and even an A/C unit in the summer (or go big with split heat pump unit. That would make the space inviting regardless of the weather outside.
I know, right? Can you believe the nerve of some women? Wanting to put a running vehicle in a garage?
plan to get SWMBO on board with the changes I want to make to the garage. And it's as much a trial run or test for me to see if I could survive in a house with a normal 2-car attached garage. A couple places we'd like to move to have very expensive housing so sacrifices would have to be made. I'd like to know if I could make it work BEFORE we moved.
Looks pretty good, how do you get the bike up there?
(ask me how I know That is one busy week of Tetris you have just had BM
20' containers are awesome, they will eat a lot of stuff and get to the point where you can't walk into them also. Before you part with any shelving from the garage you may want to use it in the container for a bit. I find shelving with totes works well initially until you end up dumping **** on the floor and you can't get in there any more(ask me how I know
Good to see you have a rough plan for the garage now if you are staying put for a couple more years, see if you can work in the welding table as a permanent setup. I think you will cuss if you want to do a quick fab job but have to set it up each time. But then again I understand it's a small space and there are compromises.
Cheers GB
Nice work on that bench, I have been collecting parts for something very similar. Mine isn't going to be quite as tall and will be slightly wider. I'll just load using a ramp. I'm also using 4x4s. More like this, but a little bit higher and with perpendicular surface:
Cool BM it sounds like you just scored some QST and 3D printer time.
I'd missed the lilscorpion new thread so just binge read that over the last 2 nights, but I'm going to stay out of the 3D printer thread for now - I want to go down the hole but need to get some other stuff done first
GB
No work done to the garage yet. I still haven't broached the idea of the major renovation on the garage to my wife yet. Her focus is the basement remodel after we have the basement walls professionally water-proofed this year. I'll just make sure I keep two pieces of plywood that I would need to finish the extra walls if she is game to the change. I think the bait of actually being able to park in the heated garage will be enough to sway her.
This week I did have a little time to grab a couple of parts for the CX500 build... it's all documented in my GL1100 thread.
While visiting my motorcycle mentor, he gave me an older cushioned floor mat:
It was really grungy but cleaned up nicely. Eventually it will be on the floor in front of my steel workbench.
I still have more sorting and purging to do in the garage. Now that I have the plan for my CX500, GL1100, and the future KZ440 & CB650 builds, I need to purge motorcycle parts I was sitting on until I decided the direction I was going to take with those builds. I need to take all of the totes down from storage, sort the parts I'm keeping for each build, label the totes for each project, and put them back up into storage. The parts I won't be keeping will be traded off to my favorite motorcycle salvage yard. I need a second set of heads for my CX500 to have rebuilt so my plan is to trade in all of my good parts I won't use for a set of pulled heads plus a little cash. I could probably get more money selling them on eBay, but for me it's too much hassle and trading them off is easier.
Then I have to purge **** from the steel shelving units. The small stuff I plan to keep will be put in labeled totes and put up in the storage loft.
Oh, I’ve been away for too long. Awesome Tetris work! More awesome the working table. Looks rustic, just the way I like. Pretty cool!
I have a variety from very small to obnoxiously huge crescents. Love them. So handy as long as the nuts aren't rusted or brass.
I feel that you are doing the same thing as I am, except my stuff is suburban instead of bikes.
Sounds like you have a good direction and the wife seems to be as close to onboard as possible. Have you figured out the conex yet? I love mine, but as GB stated, it fills up quickly.
I know the feels. I just picked up a project boat and I need another project like I need a hole in my head. Good news is I've started to move more **** on fleabay.
I will never own a “project” boat again. I played that game a couple times and I either gave the boat away or paid to have it removed. The last one I actually got paid for, but the headache it caused was in no way worth the money. I will let someone else own the boat, or I will rent one. If I lived on an island or a lake, I might feel different, but I don’t so that is it, end of story.
Waiting definitely makes sense, sounds like you will have lots of time, don’t waste it like me. I can’t believe how much time it takes me to do so little.
Really, the more I think about it, you should look at buying a conex. Then when you do move, pack it up and have it hauled to the new place. They will probably charge you $100 or more a month, plus delivery and removal. I bet you can buy a decent one for a bit over $2k delivered.
Got it, I forget sometimes that not everyone has inside and outside forklifts.
I think you're the only one with both...
Great news about the brake rotors and even better news about the totes, one tip I have is to label both ends of them, that way it doesn’t matter how you put them back. Sounds like the wife is going to get to go on a motorcycle ride soon.
I thought I was your big fan?
I hate heat, it wasn’t nearly as hot here, but it sure was humid. I am an efficient cooling machine as well (I sweat a lot too).
Even with the heat it sounds like you still got a lot done.
Boilermaker Fan,
Sounds like you were busy this weekend.
I wish we could get some of that heat up my way.
