Kinking 1" EMT
gotham
Colorado
I'm running some 1" EMT in my garage. First piece with a couple 90s and an offset went fine. Second piece I can't bend a 90 without kinking it. I'm just under 200 pounds and it's taking all my weight to bend. Any advice?
Kevin Essiambre
Ottawa, Ontario, Canada
I've never had issues bending 1" EMT and it kinking, and I weigh around 200 lbs as well. I have had issues with not being heavy enough to get it to bend on some brands of conduit, when that happens, I usually jump a little onto the bender while pulling down.
I've had issues with conduit kinking with proper foot pressure, and had conduit split open while bending it. Both instances were bad batches of conduit.
Foot pressure is key with bending EMT. Without it, it will kink. I'd try more foot pressure. You may want something to hold onto so you can get your whole body weight behind it.
Just my 2 cents.
Sent from my new phone. Autocorrect may have changed stuff.
Charlie K
Baltimore
I am going to say not enough foot pressure. Foot pressure is important. The pipe in the picture looks like you tried to bend it in the air.
ycgoat
S.E. Va
Yeh foot pressure, I have to kind of jump the foot and pull back on the handle at the same time (185 lbs)
nadogail
Coronado, CA
Jack Benfield wrote "the book" on hand bending EMT. IMHO, there is no better reference on the subject. The Benfield Conduit Bending Manual, available from Amazon.
coljar
Belpre, Ohio
I didn't have a 1" bender, so I bought pre-bent 1" 90's at my commercial electric supplier and used straight connecters. A whole lot easier when you get up into that size of EMT.
G
gotham
Colorado
I'm using a bender. Both feet on the bender. One hand on a table for balance. One hand on the bender. I don't know how I can get any more foot pressure.
Old Man Roger
Palm Coast Florida
I don't know if this applies, because I've mostly bent scheduled 40 water pipe, but the lower quality stuff I've worked with needed a little creative ingenuity to keep the center of the pipe rising out of the middle of the former.
Could you use a clamp of some sort to hold the conduit tight on the arch? If it can't rise out of the form it shouldn't be able to kink.
kevink1955
Suffolk Ny
Like has already been said foot pressure, only pull on the bender handle not the end of the conduit. pulling on the conduit causes it to slide in the bender and kink.
If your conduit slides in the bender the bender may be worn, clamp the conduit to the top of the bender, you cannot let it slide at all
Old Man Roger
Palm Coast Florida
Try heating the conduit a bit where youre going to bend it?
Without filling the conduit with sand or something I believe this may end kinked as well. Plus its galvanized conduit...
Ya heating galvanized conduit makes that pretty yellow gas that messes with your nervous system, probably not a great idea.
Bogie1632
Southeastern Wisconsin
As has been said... foot pressure. Eat your wheaties. I find it easier to stand on the conduit with one foot as I step on the bender ( straight down as it rolls) and pull (keep it aligned with the length of conduit). Conduit has to stay in the benders groove as you go. I've gotten links if I let it slip a little. For me, it seems to help keep everything aligned with my fatness as I bend by stepping on the conduit. YMMV.
Good luck.
V/R
Bogie
Kevin Essiambre
Yes, I'm not too fond of that yellow gas... I have almost unlimited amounts of galvanized material that we weld... a big fan helps with that gas when welding...
Miss the Pontiacs
Saskatchewan Canada
Pull out an extra foot of conduit. Long length on the floor. Bend away from the short end, one foot on bender push down steadily. Cut off excess from the one foot if required for fit. Just use connectors and cut accordingly.
How are you even using both feet?
sparky 1971
Central Iowa
Try putting the end of the conduit against a wall before you bend it. I have never had trouble with 1", but 1-1/4" will occasionally give me problems when using the step bender. Also, if you are bouncing on the bender to get it started, make sure it isn't moving around on the conduit.
G
gotham
Colorado
Thanks guys. I'll give it another go. Bender is definitely not worn. I'm pretty sure it's not slipping.
I get one foot on the bender, lean back, get one hand on a table to balance, then get my other foot on the bender.
Terry D
St. Louis, MO.
1" can be tricky to bend. It has to be a steady foot pressure, to much, and the bender will want to lift off the ground before the 90 is bent and this will cause a kink. if the pipe is slipping in the bender, this will also cause a kink. A lot of times, I will back the conduit up to a wall, so when you bend it, it will not try to slide on the floor. With those seams opening up like that, there is a possibility that the conduit is defective. I have seen it before. Only other thing is that there is something wrong with the bender itself. Did you just buy it? if so, maybe exchange it for a different one
Marctrees
TX/LA border - Toledo Bend
"A lot of times, I will back the conduit up to a wall, so when you bend it, it will not try to slide on the floor"
I never did much over 3/4, but I do recall this trick helped alot IIRC.
Marc
alfredeneuman
Fullerton, CA
To emphasize the importance of foot pressure>>>
1-1/4" EMT benders have an extension to the "foot" that increases the leverage.
I've never seen a 1" with the feature though
sberry
Brethren, Michigan
I have an inch. Can't even remember the last inch I used wiring. On small jobs/building gs I never use it, every wire in the place doesn't need to run down 1 pipe and a few are single circuit. It's another layer of fittings and boxes I dont care to stock.
It doesn't help the op but it's something to think about for others designing most garage wiring.
