Kitchen Lighting Remodel
D
dsaunier
I've used the stud finder to space the first 3 of six on the sink side perfectly. I'm gonna get up there tomorrow with a respirator and goggles and climb in 2 feet of blown in insulation through the crawl space and measure up the backside facing the range. I'll also have to remove the other 2 florescent lights after that. Then I will cut my 6 holes and drop in the cans - hopefully. The only restrictions I may have are potentially having to reroute a/c duct lines in one area. Here is the LED light/trim combo I found for $24 at Lowe's: http://www.lowes.com/pd_113539-59179-DLS02-06A27D1E-WH-F1_0__?productId=50188783. Thoughts?
D
dsaunier
All done. 6 total 6" cans @ 13 watts per.
alfredeneuman
Fullerton, CA
Most Energy Codes have limits on kitchen lights, that pretty much eliminate incandescents or halogens for general lighting.
A certain (high) percentage of them have to be energy efficient, such as LED or flourescents.
D
dsaunier
and then?
alfredeneuman
Fullerton, CA
You'd pass with flying colors. I noticed when you said 13 watts per fixture, and figured since you didn't like fluorescents then that was the obvious conclusion :)
I said it for the benefit of others, that recommended that you should have 500 watts of quartz halogens.
D
dsaunier
ah gotcha. I'm still curious though because the Halo can lighting fixtures say they are insulation safe. Is it really a good idea to throw blown-in insulation up against these fixtures?
alfredeneuman
Fullerton, CA
If they're IC rated you can have insulation no matter what type, up against them.
IC rated fixtures (Insulation Contact) don't have any holes in them, whereas non-IC housings do.
D
dsaunier
okay perfect. one other question... is it normal for LEDs to flicker? I noticed one or two of the 6 will randomly flicker every once in a great while. I am going to recheck the quick connects, but I'm pretty sure they are solid. I know there isn't an issue with the wiring on that run.
D
dsaunier
I think it might be the dimmer. It comes with a black, red, red/white, and green wire. My previous switch for these lights just had the 2 black going in and a red going in. When I hooked up the new dimmer, I just hooked up in following fashion:
Red wire of dimmer to black in wall
Black wire of dimmer to red in wall
red/white capped off
green capped
the other black in wall that was going to the previous switch is capped
Please advise!
