http://www.amazon.com/gp/product/B0000302VW/?tag=atomicindus08-20
Saw a vid where he likes these better than SO, Matco, etc.
1 pair for $23.14 or 2 pair for $59.99![]()
Blue handled 2000 series better than the red handles,they have hardened jaws.Have Knipex,Diamond ,Snap on,as well I like them all.
My current pair is harbour freight. What's the cheapest value to upgrade? Spend the least for the most leverage upgrade?
Sent from my XT1575 using Tapatalk
Knipex is definitely better imo. I'm looking at the Irwin NWS powergroove, based on videos and reviews, I think those may be even better.
I have the NWS fantastico, and while they offer more leverage, you loose a lot of opening between the jaws. You can't fit anything large between the jaws, and your hands have to do ALOT more moving for just simple cuts.. Unless you have something really hard, that's really thin - your not really gaining much advantage.. It's a lot more hand moving, which was more of a strain to open and close them all the way for even small things.. I went back to the Knipex after a day.. It's worse than the crescent pivot pro's - which aren't a bad compromise if you really need more leverage..
As much as people call them junk, I still say the crescent compound action cutters offer a lot for the money.. They are some of the cheapest, and best performing cutters for the money if you need to use them a lot. The spring loaded handles alone are worth trying them.
I have about 10 different brands. I prefer the Knipex over all of them.. I don't really understand the idea of diagonal cutters that "aren't meant" to cut certain things.. Why bother with the inferior set from the same manufacturer when the other can do everything??
Anyway, the jaws on my Knipex are still perfect and they don't get used lightly.
No idea why, but they are available as a single tool in both blue and red handled versions.. They are identical..
Red - Apex Tool Group PS5429C PRO Series Diagonal Compound Action Pliers https://www.amazon.com/dp/B000TDDP6E/?tag=atomicindus08-20
Blue - http://www.homedepot.com/p/Crescent...gclid=CNvr_PCVq8sCFYwkhgodtEABUw&gclsrc=aw.ds
They are available in Sears by themselves, or with the matching lineman pliers in a set for $25 for the pair.. I've seen just the cutters as low as $9 on Amazon at one time. They are NOT like the compound cutting Dewalt version. I have those too.. They are horrible compared to the crescents in both form, function, and quality. Crescent also makes matching needle nose.. The lineman pliers have a unique designed head with will also grab onto nuts,bolts, and small pipes..
What many people don't realize, is that the spring loaded handles on the crescents stop at a detent. It allows a stopping point for easy hand action and opens wide enough for most cuts you'll ever need to make.. HOWEVER - they open wider, PAST that detent.. You have to pull the handles apart - like separating a socket from a ratchet. The first time will be hard to do. But the handles will spread open as far as 180 degrees allowing for BOTH the compound action, and a wide throat between the jaws. I used these for years until I switched to Knipex. Quite honestly, I might even like them better than the Knipex, but the Knipex quality is superior in part due to its simple design. The jaws on the crescents will withstand almost anything, and the design tapers down to a slim point - allowing for access into some really tight areas. Great for cutting tie wraps and zip ties that are wrapped around wires and cables.
I just need a pair for cutting copper wire.
Thanks, added to my wish list and going to check today to see if HD has them in stock. Was planning on making a trip anyway.
Which model of Knipex dikes does everyone prefer?
I have a pair of 15 year old Kleins that work fine,but are getting a little dull.
If I am going to purchase a new pair, just want to give the Knipex a look.
I like the other 2 Knipex pliers and pliers wrench that I have.
I was sold on Knipex with the mini bolt cutters, bought the 10" diagonals and as some destructive testing, snipped thru a straight razor blade in 2 cuts. That impressed me.
hd does not stock them.. Only place I've seen them in store (lately) is Sears.. Sears has the single set, and the cutter / lineman plier set, usually with the long nose available as a separate purchase, all in store on the peg hooks.. You can order them online from a lot of different places though.
Found that out, they have a different diagonal cutter in store...those were $17 and seemed nice but a bit too much flex in the handles for my tastes. Might just order the ones on Amazon, doesn't hurt with Prime and if I hate them I can return them.
Yea the model HD stock from crescent are the pivot pro's, the channellock 337's and 3 sizes of Milwaukee. I have the pivot pro's, they aren't bad, I have the channellock 338's. and the 338xlt's, every size of the old Milwaukee's (I hate to admit that they are horrible) and the 8" set of the newer milwakee. Which was a huge improvement but not on the level of the pro brands.. they probably have the compound cutting dewalt, I have those too, they are beyond horrible, and standard style dewalts I wouldn't bother buying. In the electrical isle they have both model of Kliens, I have the red handled versions, and some commercial electric versions - that I also own.
