Knife sharpeners
vpracer
What do you guys recommend. I have lots of different types, cooking and hunting so is there a sharpener that will handle all kinds of knives?
Lots of internet reviews and options but just looking for real world feedback. Thanks in advance.
BetterDays
I picked up two whetstones to learn myself. I have an electric one, but realize knife sharpening can be a skill to learn.
(also commenting to be able to check replies)
ChefRex
Funny, I was just finishing sharpening a couple knives with my Gatco kit, not prefect but works well enough.
Doing it this way is definitely a skill. Like any skill, it must be practiced OFTEN before you are good at it.
IMHO, any system that holds the blade at the proper angle and includes several different stones, is the way to go.
Augus7us
Central Ohio
Wicked edge is one of the best sharpeners out there. If you want powered there is tormek. If both are out of your price range look for the knock off wicked edge type sharpeners.
Fuelboat
Wicked Edge also, had mine for 4 years no issues with it other than it is a little expensive for some people.
ericm
Southern Oregon
A stone and oil is all you need. Or a Harbor Freight diamond hone, and water. (get the one that's a block, it will be easier to use than the set of three flat hones).
The hones are nearly as good as a good set of coarse and fine stones, and make less mess.
It's super easy to sharpen knives on a stone/hone, and it gets them a lot sharper than any sharpener I've tried.
shoot summ
I've been on a sharpening kick lately. Use my 1x30 belt sander with various grit belts up to 2000 if needed, and a leather strop belt. All of our knives are as sharp as I want them to be. Seems that touching up the edge with a 400 grit belt and stropping will get it sharp enough. I like to at least go up to 1000 grit though. I have no hair on my arms after sharpening every knife in the house... :)
I can do a kitchen knife in a couple of minutes, 3 swipes each side with the 400, 3 swipes with the strop. Almost takes longer to change the belt than anything else.
V
vpracer
Thanks for the feedback. I will chase down a wicked edge. Those look very nice. Their website says out of stock but also says a sale is coming soon.
jshillin
PA
Ken Onion Work Sharp is what I've had the best luck with. I have a Lansky setup also and it works fine, but I prefer the KO.
brianh
grahamsville NY
Arkansas stone is my favorite along with a leather strop powered or an old belt, stropping gets microscopic bits and polishes the edge. I can shave hair when done.
I use diamond and Japanese water stones but the Arkansas is used the most.
TMcCay
SW. Oklahoma
TSPROF for me. I love that I can use just about any stone I want. I can make very small changes to the angles and very easy to make micro bevels if I want. Easy to setup and use. It was pricey though.
BetterDays
@Eric,
Any recommendations for a beginner? I have coarse and fine stones and have tried it a few times. My process will improve them, but not really make them extra sharp.
Any advise is appreciated.
HenryAZ
MEMBER EMERITUS
South Congress AZ
I hope someday to acquire the skill to do the angles freehand on a stone. In the meantime, I cut three blocks of wood at 20*, 22*, and 25*, angled on both ends. I topped the angled parts with a thin (1/16") piece of uhmw, to provide lubricity and prevent scratching the blade surfaces. I clamp the block lightly to the stone (stone in its box) to prevent movement (not enough clamp pressure to break the stone, and I move the blocks to different places on the stone). I use two oil stones, each with different grits on each side. An India oil stone with coarse and fine sides, and an Arkansas stone with soft and hard sides. Keeping the blade against the angled part of the block works great. Having the same angle on both ends of the block makes it easy to do both sides of the blade without changing the setup.
ericm
Southern Oregon
With that are you drawing the knife across the stone lengthwise? I have always moved the knife along the stone perpendicular to the cutting surface.
Most knives's cutting edges have a slightly rounded shape like the bottom of a boat. I don't know the common term for it, I call it "rocker". Pulling lengthwise you'd have to subtly change the angle as you pull to keep that consistently on the middle of the stone. Going sideways you can feel that the knife is centered.
It seems like the block idea could be useful for sharpening across the stone. Maybe just put it at one end and use it to set the angle when you start.
@Eric,
I think the important thing is to keep the angle consistent and take your time. I often put the blade on the stone without moving it to look at/feel the angle and feel that the rocker of the blade is centered on the stone. Then when I'm happy with it, take a stroke.
Also don't worry about experimenting. If you mess it up you can sharpen it again.
exmaxima1
Midwest
I've been on a sharpening kick lately. Use my 1x30 belt sander with various grit belts up to 2000 if needed, and a leather strop belt. .......
I use a 1" wide belt sander as well. I bought an angle jig that attaches to the platen and it makes it very fast and easy.
LuvAZ
Scottsdale, Arizona
I bought a Lansky sharpening kit about 20 years ago and never looked back!
It came w/a variety of stones and angle-holders so you can sharpen just about anything- even razor blades!
HTH,
Will
NETexas
Attached
Diamond Lansky will do just fine almost every time. Trick is to finding out what degree angle the knives are shared to from the factory. If you get that wrong it will take you longer to set a new angle. Also log what angle is on what knives.
californiaHank
Mostly I agree, but it's not rocket science. You just need a bit of extra care and patience the first few times - and maybe you should practise with that old carver before you work on your fancy Japanese chef's knife. There are a lot of sharp edged tools in the shop, and basic 'whetstone skills' really pay off over time.
shoot summ
I tried that, don't like that the belt is running against the blade though. I've gotten really good at doing them without a guide.
exmaxima1
Midwest
I know what you mean, but my homemade sander has a reversing switch so I can keep the blade from snagging the belt.
bushmechanic
edge-pro knock off
Edge-Pro sharpening systems are pretty darn great:
LS6 Tommy
Northern NJ
Check out Wicked Edge .
Really, really good, but too spendy for me. I did a lot of research earlier this year before I upgraded from my old Lansky kit. I ended up getting an Edge Pro Apex 4 kit. Best system (other than the Wicked Edge) I've used. The Wicked Edge Go is very close in price to the Edge Pro Apex 4, but once I added the cost of all the additional stones I'd want, the price went way up. When I hit the lottery I'll get a Wicked Edge. KME makes a good kit, too. It's kind of a melding of the WE and EP systems.
https://www.edgeproinc.com/?gclid=C...hkK7LQeV9OREN6xDOOHlR7epfP5CfFEAaAnJeEALw_wcB
https://www.kmesharp.com/
Tommy
HenryAZ
MEMBER EMERITUS
South Congress AZ
I am drawing the knife across the stone, exactly perpendicular to the stone, and following the curve of the blade as I go. On a really long blade, I will break it into sections, as I get better results than drawing a long, curved blade in one stroke.
I used to work (for 25 years) in a custom millwork shop, and this action is very similar to working radius pieces on a shaper, face of the piece against the cutters, where you have to keep the part of the workpiece that is in contact with the cutters exactly where the spindle is as you "roll" the workpiece around. I did that type of work freehand, with only springs to hold the work lightly against the fence.
I am still experimenting and hope to move towards not using the blocks. Yesterday I tried using slipstones (about 4" long), freehand along the blade edge, with the blade resting on a clamped down piece of 2x material. That worked surprisingly well. Having done my own pocket knives, my wife is throwing all her kitchen knives and scissors at me now, so I have a good supply to learn on.
Sharpening Supplies is a good resource for all types of stones and sharpening equipment, including all of the brands of sharpeners mentioned in this thread. I don't know if they are the cheapest, but they are a responsive small business and a pleasure to work with.
