Kobalt Compressor help. (Repaired)
P
Pucman1
Northern Va
Well it appears that Saturday may be delivery day so thanks again for all the information and then we can install a couple parts and see what we have… so far only 25 bucks in…
P
Pucman1
Northern Va
good luck with it .
couple parts?
what other than the overload are you replacing?
do you plan to do one at a time or all together?
Circuit breaker is coming first, then couple days later the run capacitor shows up… I will try parts as they arrive and see if it fixes the problem…. Last item would be the regulator but even then I am out like 50 bucks././total. Maybe someone adjusted the presets out and that is why it is kicking out, those wires do go back to the motor. Can’t find any documentation on the original!
P
Pucman1
Northern Va
Don't tear into the compressor pump just yet...
Edit- too late.
Thanks everybody for all the comments. It was the 7.50$ part that fixed the issue. Got the new breaker and installed it. Fired the unit up and ran straight up to 150 psi, popped the pressure valve…. Back down to 0 and repeat of the start up….straight back up to 150 psi….. pretty sweet compressor for 7.50!
Thanks again for all the suggestions
P
Pucman1
Northern Va
Shut off and kick on working perfectly. Just did that to empty the tank and check it for a 0 to 150 psi run up…..it was flawless
Citation
Indy
In all the various "why doesn't my compressor work" threads I think this is the first time I've heard of the breaker being the issue. I'm glad for you it was a cheap fix. Given the compressor's age is very clean. Hence why I'm surprised anything is wrong with it. Either way, glad you are up and running!
  • Like
Reactions: RTM
P
Pucman1
Northern Va
Thanks, only thing i could come up with is maybe whomever borrowed it used a extension cord not rated for the electrical draw. So gonna pipe it in and start getting some miles on this unit.
