I think it will become obvious if you look at a picture of the profile.
The amount of material they remove during manufacturing determines how far a socket has to rotate before contacting a fastener.
With this type of socket, they remove
a lot of material from the corners of the socket so that it engages
much further back from the corners of the bolt. The benefit is that the socket is very unlikely to round the corners of a fastener. The consequence is that there is more empty space through which you must rotate before turning the fastener.
It's a kind of bitter consequence, too, because unless your ratchet has zero backdrag, you have to travel through the empty space once as you ratchet back, and then again as you start to turn. Not as big a deal if you hold the socket the entire time, but you can't always do that.
