Kraeuter
Kraeuter 4501-4½ - 4.5 inch diagonal cutters
Kraeuter 4600-6 - 6 in. diagonal cutters
Eric Brown
Kraeuter 5 1/2" bent nose pliers. Marked Kraeuter 1913 - 5/2. Nose is only about 1/8" thick. While AA shows these in a catalog add, they only have the larger 8" and 10" versions pictured. Perhaps these are rare?
Mintgrun
Kingston, Wa.
There is so much wear in the pin that the jaw alignment is compromised.
I googled 'vintage kraeuter tile nippers' and this #1851 pair came up.
Tile nippers jaws aren't meant to touch, so I'm guessing that's their intended purpose (so is the ePay ad the ones above were in); but I have not looked them up in any catalogs.
I did look at other google image results for that part number and the jaws don't touch on any of them, so it isn't a matter of pivot wear. They were made that way.
Mintgrun
Kingston, Wa.
Okay, I dug into an old 1937 Kraeuter catalog and the 1851 nippers do not specify tile cutting.
I found another pair of 1851 nippers on ePay that do show them in a fully closed position with the cutters touching. I don't know if they even made tile cutters and am embarrassed about sharing a definition based on ePay listing info.
Here's a photo of another pair on ePay.
I'm sorry for doubting your pivot assessment, @d42jeep
^ THIS is the end result of ebay's "AI" bot pumping misinformation onto the internet. I've seen 4 examples of it in the last two days.
ebay's "AI" generated ad descriptions for vintage tools need to be taken with a gigantic grain of salt, if taken at all.
Mintgrun
Kingston, Wa.
Thank you for that photo, Don. I was confused, because I couldn't understand how pin wear would keep them from closing fully. This photo makes it very clear that the pin is compromised.
nz44tool
New Britain CT
I'm a big Kraeuter fan. Here's some of mine. Sorry about the randomness in the pics; I had to separate the keepers from the listed and not-yet listed.
- not very good pics, now that I look at them. If anyone's interested enough, I'll re-take them.
MisterEd
Florida
Kraeuter 5601-5 Diagonal Cutting Plier (Needle Point)
misterbill
A couple of nice 5-inch variations. Both have an OAL of just over 5". Neither has a side cutter. The duck-billed ones have "601-5" stamped on them. The other pair is stamped "16?1-5". I'm guessing that the "601-5" is really a "1601-5" with the "1" worn off as it seems to match the catalog drawings. I haven't seen a match for the other.
Bill
nz44tool
New Britain CT
Bill
Gorgeous. I'm very jealous.
Picked these up at a flea market
Nice find! (And mad respect for a fellow fleamarketer. :))
Those pliers are quite uncommon. Note that they generally resemble lineman's pliers, with side-cutters, in shape and profile and construction, but they have that serrated jaw opening more reminiscent of slip-joint or gas and burner pliers for small pipes and pipettes, plus two additional wire cutters of the Button's pattern type around the pivot, and on top of all that, handles that terminate with a screwdriver and a punch, spike, or awl, also reminiscent of some gas and burner pliers, and also sapper, explosive ordnance, or blasting cap pliers.
I have a funny bone for multi-tools, to start with, and it extends to pliers, but I have only ever seen and found two (2) pliers with that same exact and highly unusual combination of features in the wild, one of them Berylco and the other an older Red Devil, both linked HERE.
59Sled
Santa Clarita, California
Thanks. I'm fairly new to collecting tools. I collect whatever catches my eye or odd looking ones.
I grabbed these because of the handle pattern. Good to know they are a little on the rare side.
MR.X
Kraeuter with a mid 30’s Blue Point and Par-V… I know there’s only so many styles possible of single offset box wrenches but these are pretty similar.
fishwatcher
I picked up a pair of Kraeuter linesman cutter pliers #1380-7 this weekend at a flea market. I’d never heard of this brand, but appreciate finding a dedicated thread here on GJ.com.
This model has been around for a very long time, but I don’t know what year range this particular variant is from. It’d be great to know from experts here.
The action is smooth and loose, with only the slightest bit of play, the build is super solid, and the cutting of paper clips and safety pins (I didn’t have any cables or wires nearby) is doable and snappy, but requires a firm squeeze. image.jpgIMG_7552.jpegimage.jpg
I’d never heard of this brand...
Pronounced KROY-ter, if you're curious. (A periodic topic of discussion.) Although I'm sure there are plenty of people running around saying CROWD-er. :)
...but appreciate finding a dedicated thread here on GJ.com.
:thumbup:
I'm no expert, I have some pliers, but mainly collect the antique ornate wrenches they made. I would say late 40's or 50's. That marking style on the pivot predates that a little but that's when they fully moved to smooth handles, no more elegant knurling, prior to cushioned grips in the 60's, just before they were bought by Symington-Wayne, the same company that bought SK.
There are some catalogs available on Internet Archive in the International Tool Catalog Library.
nz44tool
New Britain CT
Alloy Artifacts has a similarly-marked pair that they date to the 1940s - 1950s.
