LAN Cable In Feeder Conduit
zendriver
Indiana
My electrical guy has run conduit for 100 amp feeder, to the garage and will finish next week..
I have not talked to him about it yet, but is it possible/problematic to include an Ethernet patch cable in the run?
Thinking I'd maybe just hard wire another router out there, verses just depending on WIFI.
Thanks
Zmann
Arizona
I do not believe that is allowed but using the same trench is permissible , and they have direct burial cat 6 so it would be easy
Zmann
Arizona
Matter of fact I may just run a data conduit in his trench and future proof for cameras/doorbell/alarm/flood sensor and other stuff you may be out of wifi range for
Don1357
Palmer, AK
Most network cables are unshielded, the EMI from a feeder cable could mess transmission enough to render them incapable of passing data. Even shielded cables would have a hard time against the volumes of EMI a hot 100 amp cable can pass. Even if it was legal it would be a bad idea.
jdm5
CT
It sounds like now is your chance! Put in 1 1/2 or 2” conduit for low voltage future use!
TuxThePenguin
Run a second conduit and/or use fiberoptic which is nonconductive (edit: only if you specifically buy fiber that is nonconductive) and legal to use in this manner (ethernet cable, having electrical conductors, is not legal to use in that manner). Personally I recommend using fiberoptic in a separate conduit (i.e. both options together).
rlitman
Long Island
Run a second conduit and/or use fiberoptic which is nonconductive and legal to use in this manner (ethernet cable, having electrical conductors, is not legal to use in that manner). Personally I recommend using fiberoptic in a separate conduit (i.e. both options together).
Not all fiber-optic cable is non-conductive. Many fiber-optic cables have metal inside to protect the fiber, and few of those have grounding means, so they are NOT all legal to run with electrical wires.
TuxThePenguin
good point
jeepxj
is the trench still open? drop a 3/4" pvc conduit run in there. you can share the trench. you cant share the conduit.
Norcal
I would oversize it a bit, 1” or maybe 1 1/4” due to current shortages of PVC it could be expensive to get crazy.
