large oil filter wrench
otis66
I would get the large filter pliers. Unless the filter is in a location were pliers cannot be used. I work on School busses with Cat engines. Mercedes engiens and International engiens. This is what I use. Mine is not from MATCO but it is the same thing without the MATCO stamp. These pliers are half the price without the MATCO brand on it.
http://www.matcotools.com/catalog/product/OF29900/EXTRA-LARGE-OIL-FILTER-PLIERS/
sdguy55
Pierre, SD
What griz posted above is probably your most cost efficient bet...and i have used that plenty of times to take of oil filters.
dtt454
missouri
if your buying your filters from a cat outlet, 185-3630 is the cat part number for a strap wrench that uses a 1/2" square drive, so you just use your ratchet, when i got mine 15 years ago it was around 20 dollars.
crewchief888
NW indiana
I believe this is the one you need: http://www.tooltopia.com/kd-tools-2322w.aspx KD makes 3 sizes, that one is the biggest ^ , I have all 3, no problems with them at all.
I've got those too. IMO they're a lot easier to use than a strap wrench, especially in tight quarters.
i have a couple of the OTC versions
they work better than any strap wrench you'll ever find.
next you'll need a chain wrench for them really, really tight ones......
:beer:
