Laser receiver for harbor freight rotary construction laser?
O
olds70supreme
If nobody knows for sure of one that works w/ the HF laser, does anybody have experience mixing of any manufacturers between the laser receiver and the rotary laser itself? aka, a Bosch laser works w/ a Dewalt receiver, etc... There must be some sort of crossover, right?
Zeke
I would think a laser beam is a laser beam. You might see if you can check the specs on the HF output to determine if it will be strong enough at whatever distance(s) you need. All laser products sold in the US have to be be compliant so specs should be available.
O
olds70supreme
That's what I had thought too, but when I was looking at reviews for laser receivers, several mentioned that they only worked with certain models of rotary laser even by the same manufacturer. If a receiver doesn't work with some of the lasers from the same manufacturer, it casts doubt that it would work with lasers from a different manufacturer.
At the end of the day I don't know much about why this is, but am hoping someone can help out.
KnurledNut
n/a
Ive used several different detectors with various brand lasers. No issues.
dogdog
Just a little googlefu.
there are different wave length of laser lights and class for power etc... not sure
why don't you call the manufactures and ask?
this is the receiver's manufacture user guide and contact.
http://www.spectralasers.com/media/custom/upload/File-1416857973.pdf
this is the HF laser beam specification.
http://manuals.harborfreight.com/manuals/69000-69999/69243.pdf
Max. Output: <5mW,
Wavelength: 650 nm ±10 nm
CLASS IIIa LASER PRODUCT
This product complies with 21 CFR 1040.10 and 1040.11
Diode Mfr.: Sean & Stephen Corp.
4F, NO3, Lane 335, Sec 4, Hsin-Yi Rd., Taipen, China
Manufacture Date:
gooblunar
We do land form work. We have a mix of transmitters and a mix of machine control receivers and handheld receivers.
We have no problem with them operating correct together . We constantly check ourselves with known bench marks. Using transit and or GPS. The only real problem we have is distance. All transmitters have different operating ranges. We have Topcon, Trimble, Bosh and others.
Don't know if this helps.
