Laundry closet bottom door gap
branimal
Getting ready to cut my laundry closet door to height. What’s the appropriate gap below the door?
htmdude57
Hudson Valley, New York
Be aware that a gas powered dryer needs air supply for the gas burner. Both gas and electric driers need supply air to make up for the air they exhaust out the wall. In my house I like to put louvered doors on closets to allow for some air exchange. That's definitely what I would use on a washer dryer closet.
CombatNinja
I would strongly consider a louvered door. You see them a lot in the south and in coastal areas where you have a lot of humidity and perhaps not an 'optimized', modern HVAC system. A lot of old homes in South Florida have these doors on closets. pantries and laundry rooms to promote air circulation.
FMB4
Is there a exhaust fan in the laundry room? If so, you might consider The Cobbler's advice of 3/4" (or maybe 5/8").
CombatNinja
You need enough space to provide the makeup air for when that dryer is set to high and cranking away. Inevitably, the door is going to get closed with the dryer running. Probably on purpose to cut the noise. Likewise, somebody is also going to pile linens in front of the door for the next load and the dryer will not be able to get adequate air. That will lead to looooooong dry times and premature wear out of parts. That is why I strongly favor the louvered doors. You most often see laundry closets done with bifold doors in my experience, which don't even seal against anything when closed, so they allow adequate ventilation even closed. Not even sure putting a solid door on there would be technically to code. Dryers are the #1 cause of house fires and this looks to be a really bad idea in my opinion.
branimal
One idea to get air in the laundry closet is to install an air vent grill. Where would the optimal location be? The bottom of the top?
niget2002
Josephine, TX
I'd still put it near the floor. Probably centered on the 'lower third' mark. From an asthetics point of view, you always divide things into thirds. The dryer will still pull plenty of air through the vent. I don't think the vent would need to be right in front of the intake. We're not talking about a jet engine.
