Lawn mower storage ideas?
P0234
NoVA
So one item I seem to need on a regular basis is a regular push mower. I have a messily two (compact) car garage. My craftsman 22" mower takes up as much space as a motorcycle and a half. I'd love to figure out some way to store it and not take up valuable space.
The back yard isn't an option according to the wife.
Ideas?
zuk123
Houston TX via Chicago, Phoenix, LA, and San Diego
I put mine in a rubbermaid cabinet behind the garage.
The cabinet is about 2 ft deep and 4 ft wide and high. The front has 2 doors, and the lid lifts up.
The mower just barely fits in crosswise. I have to loosen the upper part of the mower handle to get it to fit.
Keeps it dry, and out of the garage.
zuk
Just like rharman above ^^^
Jere
You could use a bicycle lift to raise it out of the way. Here's one style http://www.harborfreight.com/bicycle-lift-95803.html.
Ken
I was thinking something along the same lines. I just made my own bike lifts and after looking at that kit. The pulleys in that kit are plastic and the rope is the equivalent to shoe string. HF sells metal pulleys on their own I would go with those and some paracord or some other cheap rope.
My idea is to stick the mower on a reinforced plywood square strap it down and mount eye bolts at each of the four corners of the board. Run rope through each eye hole and then up to a single ring and do the rest like this picture.
ChristopherLutz
Flower Mound, TX (DFW)
if you can't fold the handles, perhaps you can convert the handles to a set that does fold so you can take advantage of small shed idea.
That's what I do - my shed is 3 ft deep - hardly takes up any space.
kbs2244
If it the kind that came in a small box with handles that fold in the middle then you can fold the handles down to where they almost touch the ground.
If so, drain the gas and oil, fold the handles all the way down, and hang it on the wall.
P
P0234
NoVA
The handles do fold but it still takes up valuable floor space. I like the hoist idea but the results of a failure would be pretty bad. As far as mini sheds, HOA no-no unfortunately.
I need one of those reel types that Keanu almost eats in Point Break. I could hang that on a wall.
crewchief888
NW indiana
i park the riding mower in front of the garage during the time it gets used.
it gets parked uncovered around in back of the garage during the winter.
:beer:
88thunder
The best thing you can do is to get it out of the garage. As many others have said. Figure out some sort of protection for it and store it out of the garage...you'll never look back! The small rubbermaid shed is perfect for such a thing. HOA or not, I'm sure you could stick it somewhere outside the garage that is inconspicuous to "them" and pleasing to the eye of "her". Put as much garden stuff in it as you can and then clean up the garage. You'll feel like you accomplished something and it's a great excuse for the wife.
terry603
lol, mine sits under a typical deck w/o any cover or protection.
done this for 10 years now and it always starts in 1-2 pulls every spring
plus it has been doing this with the maine winters.
not ideal,i know,but,goes to show they do not have to be babied
shannonw
Florida
one of those rmaid sheds. I'd get it out of the garage. That said i got so sick of trying to find a place to put all the yard **** (no shed here) and with 2 kids i said why the hell and i spending what little free time i have on this and i got a service...but mowing in florida summer humidity gets kinda old =)
When i did have it i folded the handles and put it under a work bench. At some point i'll do my own again but there will be a shed no hoa where i'm at. With only a 2 car the number one thing that drives me nuts is staring at expensive space populated with yard **** (but i'm not a yard guy).
If hoa, Maybe you have a deck you can conceal it under?
Oldbear
Linden, Alberta, Canada
Under the back of your hot rod...
Find a way to hang it on the wall or ceiling. Or build a garden shed/box to store some of that kind of thing.
camarotoolman
cocoa Fl.
I'm scraping mine and buying another ************* one in the spring. It was a good one, payed $20 for it and got 3 years out of it!
pipsters
USA
I have an electric one. With that you can hang it vertically on the walls if you'd like. I do not but I have thought about it.
Rockford
So Cal
I have a similar situation and plan on making a simple, elevated platform to wheel my front-throw mower onto and the rotary mower will slide under the platform. Two mowers for the footprint of one. Sorry no pictures, as I havn't made it yet. But it's going to be a 2' X2' plywood platform elevated about 20" off the ground with 2X4 legs. The ramp to wheel the mower up will be hinged to the edge and once the mower is up, I'll raise up the ramp and latch (bungee cord or rope tie) it to the mower's handle.
I promise- a picture once I finish making it!
taumac
Brooksville, Fl
Its really not that hard, just fold up handles and store under shelf
