Leaking fitting?
custom1
Pa
I have had this threaded fitting apart at least three times. First time I used tape and the next couple times pipe dope. Is it OK to use something like RTV sealant on it or do I have to unsolder the adapter and solder on a new one? I have a tube of Permatex ultra gold I was going to try. I really don't want to get back into soldering on this thing. It took me a few tries till I got it all leak free the first time.
The Cobbler
is that a gas shut off you're connected to?
that fitting looks like it might be overtightened and maybe stretched the valve or deformed the fitting .
if it's just an occasional drip it may seal up over time. otherwise replace the valve & the fitting
C
custom1
Pa
No, It is the hot side of my radiant floor heat manifold. Not sure if I can easily replace that part. Got it online a few years ago. I just want to get it to seal. It only needs to hold about 15 psi.
sevenzeronova
Teflon tape it then pipe dope. And tighten. Looks like there is a union on the other side to the manifold. Easy to change out.
mik386
Northeast Ct.
That male adapt looks pretty deep you might want to check and make sure there is not a hairline crack on the manifold.
