Lean to shed off a shipping container
bmxdukie
Ontario, Canada
Hey folks. I bought a 20' shipping container for storage.
I want to put a lean to off one of the long sides. Then close it in with spaces in the boards for air movement. I plan to store my firewood in this lean to..
Question is... how do I attach to the container?
Any and all ideas are appreciated.
Thanks in advance. :thumbup:
Jinks
Daytona Beach
Uh, self tapping screws, bolts & nuts, really long pop rivets, welded angle iron? The list is endless. What material are you going to use for the lean too?
bmxdukie
Ontario, Canada
Jinks, I was thinking of wood with a steel roof.
Maybe I should run a 2x6 the length bolted through the container, then use 2x6 for stringers.
4x4 posts for supports.
I was hoping to have 7' tall on the low edge of the lean to.
Voi
Western South Dakota
Not addressing the exact question but I have seen a shipping container with single slope trusses & a decent overhang on one side.
Similar to the picture below. You'd probably want more overhang.
Might be a good choice if you want some slope & have 7' of head room below the beam on the low side of your lean-to.
Doesn't need to be single slope but that's just what I remember seeing.
denis4x4
Durango CO
I welded 2” angle iron brackets on the side of the container and then bolted 4x4’s to hold Teco brackets.
Bretny
Dutchess county NY
If it's in the budget just roof over the container also. These things will rust though on the roof.
How far of an over hang are we talking with only 2x6 rafters?
NUTTSGT
Northern Central Ohio
I was going to suggest a shed roof over the entire thing myself. Check out Youtube for shop build using shipping containers.
BukitCase
Oregon
Above are some of the reasons I went with complete coverage -
Disclaimer - I wouldn't recommend doing this unless you're OK with heights, rigging, welding things you CAN'T break, having patience, and most of the other attributes members of GJ tend to exhibit :thumbup:
I built my roof solo over about a month, with the help of my old Case backhoe and several "helpers" I've fabbed as necessary, multiple comealongs, ladders, mag drill, jack stands, chain falls, etc - in retrospect, if I had it to do over I woulda probably gone with welded on angle and wood framing. Cheaper, faster, but probably NOT as modular/re-usable as the steel.
Mine is in 4 sections, a main one over the container and 3 8x12 modules that bolt together and can be separated and removed one at a time if/when necessary. There is NOTHING welded to the container - I'd do that part the same if done in wood, especially if I ever intended to re-sell the container.
With the exception of a few main framing tubes that're 1/4" wall, 90% or so is 2" square tube with .120" wall. At today's steel prices, the framing alone would run right at $1800. I wouldn't have done it this way EITHER, except future plans call for a different use of that space so everything, INCLUDING the 20' container, will eventually be moved ELSEWHERE so it would either get torn down or (because of the modular build) just "re-assembled" in a different spot.
Anyway, a few pics for the "masochistically inclined" :lol_hitti
... Steve
Worsedog
Central FL
... Steve
Holy over-engineered. I love it! :bowdown:
SweetD
Rhode Island
That's nice, well-engineered. :beer:
BukitCase
Oregon
Thanks guys; can't take ALL the credit, here's one of my "helpers", lets me move 300# roof modules over to the lift points without a second body (OR a 12' wide path) - wheels on that HF hand truck can go back on the original axle if I need another "normal" hand truck, unlikely tho since I have at least 4 others :headscrat
My friends don't disagree when I tell 'em I'm living proof that lazy men make the best inventors :bounce: ... Steve
bmxdukie
Ontario, Canada
Holy! Sorry I've been AWOL! Nice ideas. Love the steel, but likely will do wood.
Ss for stringers, I meant to have 8 to 10'out from the container.
Maybe I should weld the angle iron to the top and cover the whole thing. Pretty sure the wife will lose her mind on the cost anyway! Lol.
Thank you all for the great ideas!
rayra
Escaped from Los Angeles
seconding something like this, roof over both the container and the lean-to area.
BukitCase
Oregon
" I see a hinge point in that span that enough snow could easily find."
Yup, don't live in snow country; had about 6" back in 2002, normal is anywhere from 0 to maybe 2". typically lasts a few hours, couple days at most.
Hinge points (3 between inner and outer 12' halves) are 1/4x2 FB, full length welded to .120 wall 2" tube, clevis type hinged with 5/8 Gr.8 bolts - each 1/3 of the outer half is a separate module, (each frame section about 220 lbs)also bolted between modules with 5/8 Gr 8.
The slanted outer support poles are "sorta" temporary, splayed out so if/when I do a slab they'll be out of the way - the upper pivot joints are removable, so
once the slab is in they'll be solid bolted joints.
those outer poles have bottom adjusters (about 12" range) with bolt holes on 1" centers, and an acme thread "vernier" between them and the 4" channel feet. (feet are currently "spiked" in place with 24" pieces of 5/8" rebar.
roof covering is overlapped at the joint so the entire outer half can be pivoted back down to ground if necessary. Outer half can also be separated into 3 8'x12' modules, and moved with my backhoe.
Needed the shallow 2/12 pitch for inside height, has about 2" clearance between frame and the hoe (in transport mode) - sheds water fine, collects a fair amount of tree ****. Loader bucket with safety rail combined with 22' extenda wand and pressure washer gets used a couple times a year so I can start over with a fresh crop of tree ****.
All this because we're still waiting on an inheritance that should be settled in the next year; then we'll know if the outer half roof gets "re-purposed" elsewhere and a second (metal/weld/tractor) shop will happen, along with a 3 car garage, partly where the outer roof half is now... Steve
