Not to add fuel to this fire, but some vehicle manufacturers do explicitly tell you to put anti-seize on the wheel hub to wheel centerbore interface.
Here is an example.
Castrol Optimoly TA is just silver anti-seize. Cleaning and lubricating the wheel hub is necessary and not doing so can lead to an improperly mounted wheel. At least according to Porsche, a company devoted to engineering.
They also reference cleaning and using anti-seize on the area of the hub that centers the rotor.
The area I circled comes from the factory with anti-seize applied to it. This area is a precision fit with the rotor. The five points center the rotor on the hub.
Anti-seize should never be applied to the hub face, rotor face or wheel face. I'm not sure if this is what your quoted post is saying, or if you are telling people not to grease the wheel hub to wheel centerbore. I know other manufacturers make similar suggestions in their service manuals, I am just most familiar with Porsches.
Porsche also recommends using anti-seize on their silver wheel bolts used from about 1997-2012. Around 12-13 they switched to a black coating on wheel bolts and anti-seize became a major no no at that point. The only time I'd ever recommend anti-seize on wheel bolts or lug nuts is when the manufacturer specifically calls for it in their service information.
I just checked my Audi Factory Manual for the B8 chassis and it says to lubricate wheel studs with Optimoly. One thing I found interesting is the image below in the "Wheel and Tire Guide General Information" section, where they are suggesting applying corrosion protection in the centering area. They refer to a "wax spray"
Also interesting to note, is an a VW Touran Manual I pulled up online it says:
"Always make sure that only the centering seat - arrow - is waxed and not the wheel contact surfaces. As a consequence, the brakes would become contaminated while driving and thereby result in poor braking."
Which leads me to wonder if this is the real reason they say not to use grease on the interface surface. Regardless, safest bet is to follow the specific instructions outlined in your vehicles manual.
