Don't use a timer to cycle the power to a "Battery Tender" (battery maintainer/charger). The Deltrans and similar "smart" charger/maintainers all operate on a similar principle. When initially connected to a batter and powered up, the maintainer/charger will apply a current-limited charging voltage to the battery. Eventually, this voltage will reach about 14.5-14.7 volts as required by the battery to fully charge. The maintainer will hold this voltage until the battery draws very little current, indicating the battery is indeed properly charged. Once this happens, the maintainer will switch to a "float" value of about 13.2 volts. This is the "maintenance" charge. It's not high enough to cause the outgassing of electrolyte that causes early failure of batteries, but it is high enough to overcome any internal self discharging effects or external discharging current from the car/equipment the battery is installed in. As long as the maintainer is powered up, this float voltage remains applied to the battery unless the car is started or some electrical accessory (like interior lights, etc) is turned on and drops the battery voltage below a certain amount.
What does all this have to do with cycling the power to the charger/maintainer? When the power is turned off, the battery voltage will begin to drop, even if there is nothing drawing any current from it. If everything is up to snuff, the battery voltage will drop to about 12.8 volts and stay there. If you now power up the maintainer once again, it will start the charging cycle once again, going up to 14.5-14.7 volts, holding it until the current drops, then switching to float mode. The needless charging cycles over the float voltage can reduce battery life over time, especially in warmer climates and storage temperatures. The newer maintainers are best left plugged in all the time. They have protection circuits that will shut things down in event of failure or unusual circumstances, and they draw very little power from the line when "maintaining."
Older "trickle chargers" and so-called automatic chargers from 30 years ago don't work the same way as a true maintainer, they either deliver a lower current, unregulated charging voltage all the time which can be quite a bit more than the 14.7 volt cycle charge that the charging system of a vehicle operates with, or will shut off all charging after a full charge and either turning it back on when it drops to some certain value (usually 12.2 volts, considered as a "low" charge") and restarts the full charge cycle again, or just stays off. Either one not good for a battery in storage.
