LED Adjustable Panel Light Screw in Base $21.99
Lost Pup
Garage
https://www.amazon.com/LED-Garage-Ceiling-Light-Deformable/dp/B07BQV1CMY
Garage Light Tanbaby LED Garage Light LED Light E26/E27 Garage Lights Ceiling LED Shop Light 60W Deformable LED Adjustable Light Garage Lighting Garage Light Bulb for Garage, Working Light (NO Sensor)
$33.99 & FREE Shipping. Details & FREE Returns
Coupon
Save an extra $12.00 when you apply this coupon.
I own a few of these. They are just incredible lighting. I have some of older pull chain style porcelain bases in my basement and garage areas. These are dead simple to install and adjust. For the convenience and ease of install five stars.
Quality seems good for what they are.
Check out the reviews.
txvwnut
Bedford, Texas
These would be a lot better if you could rotate the light panels to point up where they would could reflect the light off a bright ceiling or be used in a fixture with a reflector. I have one in the attached garage and while it’s bright as hell it has a small light circle with the panels horizontal. When you start adjusting the panels to spread the light you loose good lighting under it and start casting shadows around the garage.
L
Lost Pup
Garage
What’s the lifespan of this light?
Multiple review comments report it stopped working shortly After being installed.
Not only these LED lights but other styles Of fixtures too.
Right for the Amazon Info:
【Durable & Long Service Life 60W LED Garage Light Bulb】- This 60W Shop Light have upgraded aluminum fins for cooling, stable and durable under maximum performance, over 50,000 hours of constant runtime makes the maintenance cost sharply cut down.
L
Lost Pup
Garage
I put mine to use right away when I received them. Puchased one for the basement then 2 more for the garage. Over a year plus and they are ok. Adding this one to our shed.
dacan23
RI
