Dr Stan
I have three coach lights outside by my garage doors that operate off a timer, or at least they should in which I installed LED light bulbs.
The weirdest thing happens when the timer tries to turn on the lights. The one farthest from the timer starts flashing on & off while the other two do not light at all. If I manually turn on the lights everything is fine. Also after awhile all three lights will turn on.
I previously had CFB's installed that worked just fine and as they burned out I replaced them with the LEDs.
Should I simply leave best alone and not concern myself? I'm only inquiring since I thought they should turn on just like incandescent bulbs and its really not a big deal.
Damn those 60+ yr old iron pipes inside the wall.
