LED headlamp
jjrbus
Florida
I would like a simple LED headlamp, I don't want 5 modes and Bluetooth ready with motion sensor. On off, high, low. Does such an animal exist?? Rechargeable would be nice as the ones I have had eat AAA batteries.
pbon
I have 2 of these and one is a few years old:
On high the battery has limited life but on medium it lasts a while. Bought another so I can swap when 1 dies.
I also like Sofirn lights and have a few. They are on Amazon and Ali express as well. There is a headlight for about $30 that looks good and a lot like the slonik but maybe with slightly better LED and a slightly bigger battery.
Citation
Indy
My suggestion depends on your needs. For outside/longer distances I really my Wowtac A2. However, they aren't for sale on Amazon right now. It's basically a head strap and an 18650 powered light.
However, for closer work one of the lights with a wide band light similar to these
https://www.amazon.com/dp/B091XSYW9F/?tag=atomicindus08-20
I have a set of these. I don't know if they are that durable but they are cheap so I'm willing to risk it. The wide light source really helps avoid shadows when you are working under a car. I don't like the bright red tail light (headlight and tail light work together). I ended up using my hot air rework soldering station to remove all the red LEDs.
Anyway, if you are doing up close work these headband type lights are really good.
Davefr
OR
I have some high end headlamps but this one is my "go to". I love that it's a simple interface, wide flood pattern, warm white, rechargeable and so lightweight you don't even know it's there. They are also cheap. Unless you need a narrow/intense beam these are great all around headlamps.
Pen & Wrench
Huron, SD
I have one I bought several years ago, don't always use it but it seems to be just fine for me, and its pretty simple, sorry I don't remember what brand it is. I don't even take the batteries out and it hasn't corroded up yet.
decableguy2000
I have several Fenix head lamps. Both are rechargeable have several levels but operate on memory of the level you turn it off at. Simple user interface.
sqznby
Coastal NC
On Off High Low and flood or straight beam with a twist of the head = Ledlenser MH10
Great headlamp and comfortable to.
Charges pretty quick and lasts a good amount of time.
Ledlenser MH10
Kuma601
Cali
I'm pleased with this one, the beam focus is quite useful:
On High the NiMH Eneloop Pro batteries begin to dim at about 25 minutes so running it on medium to low yield good times. It just eats batteries when set on high. For car stuffs the medium and low yield good run times.
The headlamp may be down while waiting depending on how the unit charges. I carry spare NiMh cells so that if the task runs long it is easy to swap fresh batteries in and keep going.
Maybe the FL85 for more output:
This one will also run on AAA's and a LiON battery pack:
shoeless
Houston
I have the Coast FL70R on my hard hat. It has a rechargeable battery, but can also use 3 AAA's as well. It also can be adjusted to spot or spread beam. Has 3 brightness levels, got it for ~$40 at Walmart.
Really like it, and the rechargeable battery lasts a long time even on the brightest setting. The battery just has a micro-usb port that you plug a usb cable into, so no special chargers or anything.
WWheeler
Middleofnowhere USA
I use these clip on LEDs that clip on my hat and can swivel down.
They were ~$15 or so on Amazon. EDIT: $17 here - https://www.amazon.com/gp/product/B08PKNTHQ7/?tag=atomicindus08-20
They have a USB micro port for charging.
The button with a circle on it is high, low, and off.
The other button, with a dash on it, turns on an infrared sensor that lets me turn on and off the light by moving my hand in front of it.
mslim
Fayetteville, AR
I've got about 4 Black Diamond Astro 250 headlamps. I've got 'em in the house, the RV, the cars, and the motorcycle.
The most I've paid for them is about $18. Oddly enough on amazon, they often have different prices for different colors of the same item. I always get red or some bright color that helps to find them if they get misplaced.
Chance
New England
F-22
Wurkkos HD20 is a solid choice. The Aliexpress link does not work, just search for it in the search bar. It's a right angle light that can be mounted on the head band. Its got a wonderful UI - one click to turn on, one click to turn off.
Only if you want to, it has plenty of settings too. You can cycle through different brightness modes by long-pressing the button when it's on. It remembers the last one so when you set the desired one you can just single-click to turn off, and single click to turn back on in the same mode. If you long press when it's off, you get into moonligh-mode (lowest setting). If you double-click it (when on or off) it goes into turbo mode with max brightness.
Other sweet things - it uses standard 21700 lithium ion cells but will work with 18650 too (these are the most common type, slightly thinner). On moonlight brightness, if you keep it on constantly it'll shine for two months. On some mid-setting, it will constantly shine for at least a day. In practice for most people that means they'll recharge it once every 3-6 months or even just once a year. With a 18650 it will last a bit less, probably about 10 days on moonlight mode - like the FC11 does (their most popular 18650 flashlight).
It's all aluminium and a right angle light. If you don't want to wear a geadband, you can keep it in your top jacket pocket too.
It has built in USB C charging for the 21700 and 18650 cells, so it can be charged like a phone.
It's got a magnetic tailcap so you can snap it to the car or the lift and position it so it can shine on what you're working.
It's rated to 2m water resistance and 1m impact resistance.
And if the battery ever dies, you just swap it out. You can even get another cell (they're 5-8€ for a quality one) and keep it in the toolcart, and just swap it out if it dies mid-work. The flashlight is not disposable like the sealed ones are. I always search for stuff with user-replaceable lithium ion cells - like, you can find radios that use them too. Sadly most manufacturers sold the damn things in to make it more disposable.
For flashlights, the typical prejudice against Chinese stuff is wrong. Their flashlights at the moment are really awesome quality. At least the enthusiast-grade stuff like Wurkkos or Sofirn. They use much better LED emitters and controllers than what you find in generic supermarkets, yet they cost the same. For example, ledlenser is more expensive for kind of outdated tech at the moment.
Top grade stuff is made by a Chinese guy called Hank. [Hank's lights](https://intl-outdoor.com/led-flashlights.html) are really cool, he fits whatever you want inside and even machines them out of all kinds of materials like copper or brass or titanium for the housing. He'll even do totally unique stuff if you contact him via email.
brtsvg
Fenix HM61R is what you want.
uses 18650 batteries
Forget the alkaline batteries, get the lithium 18650 batteries as they are so much better performing. Get a brand type such as Fenix or Petzl, while these brands are generally not found in common big box stores they provide much better features than those lower priced ones are are stocked in the big-box store. Don’t be afraid to pay a bit more for quality and performance, it is well worth it when it comes to headlamps.
jrsavoie
North east Illinois
I only wear lighted caps.
Sometimes I attach a clip on or ******** light with them.
I've seen safety glasses with LEDs on the temples.
Do they make LED temple attachments for prescription glasses?
I would try something like that out, if available.
Rinspeed
NY
I picked up one of those a couple weeks ago and so far I'm liking it. Only used it a couple times but if it holds up I might get a couple more for the boys. I mentioned in my other post about the weight, for some reason the headlamps with the larger batteries really bug me after so long.
Kuma601
Cali
What are your intended uses? What are the working distances for this light? Up close like 3-4 feet 200 lumen range is good. Getting further out having the spot and more output is helpful.
Muckin_Slusher
Abitibi
I've got a similar Wowtac A2 and an Energizer 18650 light. While I like this style of light, what does this one bring to the table vs the cheaper models?
I'm happy with the runtime and the 5 different brightness settings. Also happy with the on button and battery life indicator LED. I really like the red light options as it's useful light at night without bothering others or wrecking your nightvision. I would much prefer that I could turn on the red without first turning on the white light. As it is I have to turn on the white light while covering the light while switching to red.
The charger is magnetic and very quick charge. Nice because it's water and dust proof.
Also like being able to remove the light for use as a regular flashlight.
18650s are just awesome because they're so common and have so much stored energy.
I'm not really familiar with any cheaper models that use 18650s.
I'm also happy with the harness, it's got good rubber grip and is comfortable.
Not sure what else to say, but I am going to look at those Zebralights someone mentioned.
jdepiero
NE, Ohio
I have a couple of Harbor Freight's Quantum 310. I am a building inspector and sometimes I crawl through some nasty areas and even up on cat walks. If it gets knocked off and falls I'm out $12 bucks. They seem to last for a fair amount of time with Lithium batteries.
For me and my use they work great.
Chance
New England
+1 on that one too. Its what I used before I stepped up to the necklight. Surprisingly good for the price.
carmantl
The Sloniks go on sale all the time on Amazon. I have several and can testify that they are good lights.
M6erfan
'Merica!
I read the article. I didn't see anything that separates that headlamp from countless others like it.
One thing not mentioned was High CRI. High CRI is pretty great in automotive work, like when under a dash and trying to distinguish between a blue and a black wire.
I wonder if he even tried a Zebralight? The Zebralight H600Fc Mk IV is the same price, offers higher output, longer runtime, has 3 simple modes (high, med, low), and high CRI (93-95).
Indexmill
Central NC
Zebralight. Lots of styles to choose from, simple interface. 18650 rechargeable. Bulletproof. I've had several Fenix head lamps **** out/break while my even older Zebralights just keep going.
That headband @Davefr posted above looks interesting.
Nonsense. Fenix and Nitecore are awesome Chinese flashlights/headlights. They are indestructible and last forever.
Do NOT buy some POS that uses throw-away batteries; makes no sense.
Use only 18650 cells.
End of subject.
noid
Not a big fan of offset 'dual purpose' headlamps.
Biggest functional difference is probably the angle retention system; one clicks into different angles, the other is just held by rubber tension.
For those who care, its also got a red light.
M6erfan
'Merica!
End of subject.
What are you going on about? The Zebralight DOES use 18650's.
End of subject?
