LED headlamp
M6erfan
'Merica!
Biggest functional difference is probably the angle retention system; one clicks into different angles, the other is just held by rubber tension.
For those who care, its also got a red light.
I found the Fenix adjustment to be finicky. The Zebralight's adjustment is smoother, and infinite, and sturdy. OP stated he wanted a simple interface, doubt he cares about a red light. :dunno:
I never said that the Zebralight didn't use 18650s.
Then, what, exactly, is nonsense???
pizza
Midwest, USA
zebralight h600c is the best headlamp available today imo (or the floody version (h600fc) if you exclusively do close up work)
problem is...
OP would need a way to charge 18650s though
also would need to program it to make it less complex (he specified only a couple brightness levels)
so idk
M6erfan
'Merica!
problem is...
so idk
I think it comes out of the box with just high, medium, & low, IIRC. It is programmable many different ways though. I have both floody and non floody versions, I use the floody for the majority of my work (close up).
OK, I just re-read the OP, I took it to mean he wanted rechargeable batteries, not the whole light.
noid
Built in charger is also worth mentioning.
Rinspeed
NY
Most of them have six levels, all three main levels have a sub level with a quick double click.
F-22
Which have the most lumens?
What are the red and green lights for?
This is. 600 lumens
The 35$ Wurkkos has a 1300 lumen spotlight and a 700 lumen flood light. It can also be adjusted to lower brightness because you don't want it to constantly blind you. It's also all aluminum and uses a proper 21700 battery. Also, the floodlight uses a 90 CRI emitter (color rendering index) so you actually see the correct colors. The Petzl does not even specify it. 100CRI is what an incandescent light has, but many LED lamps have horrible blue light that makes it hard to recognize what you are seeing.
It's something you don't even know how important it is with a quality light until you see it side by side. It's why an old incandescent Maglite with 40-60 Lumens sometimes looks way better than much brighter cheap LED flashlights.
IMO that Petzl seems terribly overpriced
JRC3
Southwestern OH
redragoon
Greenville SC
I'm partial to the Black Diamond Headlamps. I have a Astro and a few Cosmo models. They all run on AAA so if it dies, I just chuck some more in. Don't have to hunt for a cable to recharge.
Cosmo is a good camping/general light with spot/flood/red beams. Waterproof, dimming, and can lock the buttons if putting in a bag.
The Astro stays in the toolbox. Only has 1 button and a dimming function. Also remembers the brightness setting when turned off.
The dimming comes in handy when staring at a lot of reflective metal surfaces.
Their Ion seems to have all the same features of the Cosmo in a smaller package with lower specs. REI has it for $17 now.
https://www.rei.com/rei-garage/product/155352/black-diamond-ion-headlamp
jrsavoie
North east Illinois
Is that a flashlight or a headlamp?
If it's a headlamp, could you post a link?
All I found was flashlights.
I didn't see how to attach them to the bill of a cap.
F-22
You use a headband. On aliexpress Wurkkos sells it together with their headband. You can use aftermarket ones too, since the diameters are pretty standard. For example it should fit the Skilhunt HB03 headband.
And here's a guy with the Wurkkos HD20 on his head, with the OEM headband.
It's a lot of flashlight for a head lamp though. If you want a slimmer one, there's also the HD15 which fits a 18650 cell (most common lithium ion cell used in everything from power tools to electric cars...). Since that's also quite long, the HD15 comes with a "shorty" tube so you can even use it with a 18350 cell - same diameter as 18650 but way shorter. That's way more manageable though I think the big one gives you way more versatility and isn't that heavy. Nice thing is you still have options - if you want to, you can fit the long tube and use it as a flashlight with a big battery.
jrsavoie
North east Illinois
Thanks
Bert_
NW Iowa
I've got a 600 lumen rechargeable Milwaukee headlamp that I really like. Has a simple button with ON/OFF but you can chat the brightness with a second smaller button.
shoeless
Houston
This is. 600 lumens
Not sure about green. But red is used for low light at night, where you want to be able so see stuff but better protect your own night vision.
Example, I use a red light when taking photos of stars at night. I can see the camera settings to make adjustments, but it's not so bright that I lose the stars.
Some sailors used to use them to read charts at night, for the same reasons. First saw one as a teenager off the SoCal coast, forget who I was with.
I use them for photo and star gazing, but also for certain camping type chores in the dark, as noted above.
mbunimog
Frederick, Maryland
Here is a pic of mine. Fully adjustable for up to 1000 lumens and also adjustable for focus for flood and spot light. A red light in the back increase safety on roads. Great for walking etc and the rechargeable battery is large and last a long time. Use a smaller one for car repairs but this is my preferred light. The bulk does not concernIMG_1540.jpeg me except in close quarter work
J
jjrbus
Florida
Thanks for the input, I have or
dered a couple suggested but cannot say I am excited about any of them. All I want is on and off, the ones I find are low lumen.
Davefr
OR
Beware of high lumens. There's such a thing as too bright. I have one that's so bright I can't even use it. To each his own, but I'll take medium lumen, warm, floody over high lumen any day. However it all depends on your usage.
tarbellb
Oregon
^^^^ agreed, however typically its CRI that is the culprit of "to many lumens"
J
jjrbus
Florida
I wish mini mag made a headlamp, simple on, off, twist to adjust. Still have a couple of them. Maybe I could duct tape one to my head.
sparky 1971
Central Iowa
I have two of these for work. When the battery dies on one I put the other on. While they don't have high/low, they do have a dimmer and adjustable beam width.
madison069
Monroeville, PA
Got these last month. Simple deal, one button is for continuous on and other button for motion on and off if you desire. I just use continuous on and first click is high, second is low, and you just hold the button down til it turns off. I’ve only had them for a month but I can’t complain too much about them at $20 for 2 of them. I usually charge one while I’m using the other one.
gregs
For anybody that uses this style of headlamp, how do you like it? How is the light output in relation to using it to work on cars, equipment, etc.? Like inside a car under the dash, or up on a lift, engine bay, etc. Is it better having a wide light field and a spot light on the side?
My current headlamp is old and the headband has lost its strectch. It uses 3-aaa batteries that are a pain to remove to charge. The battery pack is on the back of your head and overall is sorta heavy. It works well for the lighting part.
Citation
Indy
I really like that general type of light. I don't like that specific model as well as the one's I linked above. The problem with that model vs the one I bought (I also have one of that model) is the part on your foreheads gets just a bit warm. Not bad but just a bit. It also isn't as bright. I do like the controls better.
So having used both I don't prefer that version but it's not bad and both have that wide, no shadow benefit. They are also cheap enough that you can use them and not worry if they get damaged.
Callelle
Depew NY
I got one when I first start working in the automotive shop because of the hype, but I was never really that impressed with it.
Jokester
Thing is not everyone wants/likes a right angle type light, especially for a headtorch. I personally have never cared for anything ZL makes and apparently (from tons of complaints) their customer service is a joke at best. FWIW I've been using various Fenix lights for all sorts of uses daily for going on 10 yrs now and have yet to have a single issue with any of them. Their headtorches are by far the best I've used and seriously recommend the HM65R.
J
jjrbus
Florida
