LED lights off a plug socket
jbadjones
Attached
My garage lighting is terrible. Would there be anything wrong with running maybe an 8 foot run of led tube lights off of one od those light socket plugs? Photo for reference.
J
jbadjones
Attached
Do the LED tube lights have a ground?
Why not just swap the light socket for a receptacle?
Yes, the ones im looking at are grounded. Its the birina lights from Amazon that tons of people use.
Honestly im looking for a quick fix, and also, I usually mess everything I touch up 😆
PCustoms
VT
Well that adapter isn't going to work, and as far as I know they don't exist with a ground because a lightbulb isn't grounded.
So
Find a different light
Or
Open light fixture to confirm ground, and switch to a receptacle
nadogail
Coronado, CA
I changed my 4' fluorescent shop lights to LED modules, this was accomplished by replacing the receptacles with lamp sockets.
MovingAlong
All my shop lights are two wire, should work fine. (y)
rsanter
visalia ca
I used LED light tubes/strips from Amazon. Fairly sure they were two prong with no ground and they would plug into one another to extend them.
i put recpticles in the ceiling, easy peasy
KnurledNut
n/a
If you're dead set on plug and play, it will work just fine.
Just get a light that has a cord:
larry4406
Northern Virginia
Is the circuit not switched already?
We don't know.
If the lighting circuit is currently switched, then the existing wall switch will also enable power to the outlet and the pull chain function would be set to the on position and the chain not used. This would then turn his plug in lights on/off via the existing switch.
walta
Dutzow Missouri
The smart move is to put in the required grounded outlet.
If that is simply to much work and you’re willing to bet your life that the new fixture will not have a ground fault while you are touching the metal parts of the fixture then the screw in adapter will likely work just fine.
Walta
sparky 1971
Central Iowa
I have not seen these before. Looking into it, the outlet is hot all the time (not switched) via the pull chain.
We don't know.
I've never seen a garage without a light switch on the wall or a plug in shop light that didn't have a pullchain or thumb switch.
I doubt that turning off the lights will be an issue.
PCustoms
VT
I may have to do this same Project in my basement to upgrade a couple of lights.
I wired my garage with 3 banks of LED (left, right and front) plus a courtesy circuit tied to the stairwell lighting (which was actually done first).
Now that I'm adding a ceiling I'm considering swapping the bulbs for more LED strip, so essentially need to do the same at some point. My fixtures have all been 2 wire though
