LED replacement tubes
MO-Iron
SW Missouri
Friend gave me 24 new TGTTU 150185 OF-4BC light tubes. I know that the tubes need to by pass the ballast, but I have not found a wiring diagram. I am hoping a member can help me out.
Thanks in advance for any help.
39CAMC
St. Louis, MO
I am no expert, and am not familiar with that brand/part number, but we have been switching our office area over to LED as each ballast goes out. I buy the cheapest ballast bypass tubes I can find in 10 or 20 packs.
Anyway, all three types did the same wiring. One end of the fixture gets wired to hot, the other neutral.
HTH,
DaveW
MO-Iron
SW Missouri
Thanks for the reply. I will wire one up and try it.
If I don't report back later, may have had a blow up:shocking:
Dh3256
There are at least three types/ways of wiring LED replacement tubes:
1. plug in replacements that work with the ballast.
2. double ended tubes (shunted)
3. single ended tubes (non-shunted)
Your description is for the double ended tubes, others are wired differently.
wiring diagrams
cybrdyke
USA
2. double ended tubes normally shunted, but non-shunted might work, too
3. single ended tubes ALWAYS non-shunted
Fixed it for ya!
CD
