Left handed drill bits
bwringer
Indianapolis
I need them waaaaaaay too often. They're a necessity when dealing with vintage motorcycles.
Believe it or not, Harbor Freight sells a very high-quality set for, like, ten bucks. No idea how or why -- their regular right-handed drill bits are awful, but the lefties work great. Must be made in different factories or something.
I've also ordered them from McMaster-Carr.
dbabicky
NE Wisconsin
Right Harbor Freight, and Left Harbor Freight.:dunno::dunno:
(Right Twix-Left Twix :willy_nil)
I bought one for a bolt we broke on my mom's car, and it zipped the broken stub right out...
As long as that HF set is ABC, I'll pick it up!
Super Sport
West Michigan
I've used them a few times, and they usually work great! I got a set of Irwin-Hansons, with screw extractors, for around $40.
Karl_B
Killeen, TX
I have a basic set of left handed drill bits for bolt removal, too. Extremely handy for that bolt that stretched and snapped. Expect to use other methods for ones rusted in place.
If you are asking why anyone would need to drill a hole with a left handed bit, that I do not know.
Jbizzle
New Mexico
I remove lots of screws on airplane panels so they are a must. Bought a set of Irwin like someone else mentioned above. Rarely actually need the extractor.
mikeceli
I went over 40 years hearing about LH bits. When I finally bought a set, wow, way better on broken bolts!
I think of ALL the bolts/studs I fought without the proper bit!
mailpup
Los Angeles
I also use them for extracting broken bolts. Mine are Snap-on brand that I bought years ago when I had a Snap-on dealer.
justme-
Boston suburbs
Been using them for years - always on a broken bolt. I have a NIT 5 pc set, same as Snap-on's set which is also the same as Irwin.
I've got a cheap set from HF about 15 years ago - meh. Next ones will likely be Norseman through my local Fastenal.
ovilla
Plainfield, IL
LH drill bits can be bought individually from the snap on truck and are fairly reasonably priced ($6-15) or so, depending on size needed. Anyway, I use mine all the time to extract broken exhaust bolts.
P
pi_guy
N/A
My DeWalt does not loosen up running left handed, I often flip my ski waxing brush on left handed mode to change the load on the brush.
Years ago it was a problem to find left handed drills, now most drills sold have fwd and rev modes.
It is one of the questions I ask my interns, what do you use a left handed drill bit for?
& I asked this question to get away from the HF snappy debate but it seems where you get it is more important than the use.
jfcasey
New Hampshire
I use them a lot. They are awesome for stripped/ **** filled torx and Phillips screws. They will drill a little them usually dig in and zip the screws right out.
rslaback
Westcentral Wisconsin
So, where does find a left handed drill to put the left handed bits into?
I have one actually. It is a cheap Black and Decker corded drill that I picked up in an emergency at a Walmart. The reversing switch is opposite every other drill I have ever used. I'm always setting the damn thing backwards.
PT Doc
just thought you guys know that there will be another Norseman group buy in the next week. WAY better pricing than Fastenal. will be in hot deal forum.
P
pi_guy
N/A
I just picked up a set of Harbor Freight lh bits they are junk consistent with the rest of the products.
If you happen to have a set look at the way they are sharpened it is flat not a radius like a good jobbers drill. A few of mine like they were sharpened on a belt sander with 100 grit paper.
I did pick up a welding blanket, as I need to weld a railing in my house I just hope it does not burst into flames.
What was the COO?
BDT/NWMN
Erskine, Mn
I am 3/8 Norwegian and left handed.... I'm game for a set,, but may go a little bigger than 3/8
The empty sleeve is all that remains of my SnapOn set.. They definitely got used..
PFSard
Mesa, AZ
How many use left handed drill bits?
Not yet. But with all the good press I have read in GJ threads on lefties, I'd like to see about buying a set for home use. Any additional recommendations that were not previously posted in this thread? I'm not feeling warm and fuzzy with the conflicting evaluations of the Harbor Freight bits.
jrobb316
WI
Used rarely for broken bolts when they are encountered, but when you need them you must have a quality set. I have the snapon extractor set (Irwin) and a Norseman 19 PC set of all drill bits. The Norseman is far superior and make some of the best bits out there. I got in on a buy as someone else mentioned and they are very affordable. Irwin used to be good, now almost everything they make is trash.
Shadowdog500
Down the shore
Yes I do use them. And I agree the HF ones are really first rate. The quality reminds me of my HF colbolt drill bit set.
When a bolt breaks flush from over tightening, first thing I try is using the bolt head to back the bolt out. (You would be surprised how often this works.) Then I soak it with Kroil and try to work the bolt out with a small center pinch. (This works more often than you would think). If it still won't come out I use a left handed center bit from an old extractor kit that I never use, to get a centered hole started, then I try a left handed drill. If the drill don't catch I step the drill size up until I drill the center of the bolt out to the thread minor diameter and remove the threads. After a little practice and patience this isn't difficult at all, but I sometimes cheat with a small needle file or chainsaw file when getting close to the minor diameter of the bolt. If the threads of the bolt come out in pieces, I'll run a tap down the thread to clean all the **** out.
Never found one that I couldn't get out cleanly, but it does take time. It could take me 20 minutes or more to go through all of my steps above to get a stubborn bolt out. I've had several salt water boats. Getting broken bolts out is almost expected on any project on a salt water boat.
Oh, if the flush broken bolt is a through bolt(like in a car frame) use a regular drill bit, because you want to push the clean threads that are I the hole into the frame instead of trying to pull the rusty threads from the other side of the hole through the hole.
Chris
Here are bolts I removed from the bottom of my wife's car.
