cspcrx
Looking for a solution that I am overlooking.
I have a Rapidair Maxline 3/4" kit that I will be using to install three drops in my garage. Each drop will have a Legacy Flexzilla 30' 3/8" enclosed hose reel attached to it. Here comes the problem. There is already an exposed section of hose to connect but it does not have a swivel so the hose just twists up.
Solution one is to put quick disconnect fittings at each drop so twisting is not at issue at a cost of about $20 per drop. I am using all Legacy\Flexzilla high flow connectors as well.
Solution two is to have the Mrs thread in the hose to the block as I rotate the hose reel to keep it from twisting.
Is there another option I am missing? Perhaps more than free like option #2 but less than $20 per drop on option #1?
Thanks!
Thanks!
