Friday evening I was able to get the edges rounded over and a lot of sanding done on it. Apparently I didn't manage to take pictures.
Saturday morning my daughter woke up early. I told her I figured it was her brother up because he wanted to go to cars and coffee. Next thing you know, we're waking him up and sneaking out. Hard to get good pics when you're making sure your kids don't get run over, carrying a coffee and whatever a kid has just handed you. I've learned they don't like the smell of the old cars exhaust so walking behind the parked cars lets them make it a little longer.
The new Rolls Royce Spectre was there.
And a few Porsches parked next to each other. The Cobra was a replica.
After that I locked myself back in the shop to finish sanding since both kids had a friend over. Early afternoon I went to Walmart, swapped my car battery in the Walmart parking lot, returned the core, and picked up some groceries from the store next to it.
Saturday night my wife and I got to spend some romantic time together gluing up the table legs.
Sunday it was time to clean up the shop, install the leg levelers and get a coat of stain on it. Shockingly this mess cleaned up pretty quickly.
Leg levelers were requested on this kitchen table base. Knowing I was doing a heavy round over on this I had a feeling the T-nut that comes with the legs wasn't going to work.
Fortunately you can tap wood with regular metal taps. A bit of a complicated process because I didn't have the right size brad point bit. I had to drill a smaller size hole using Kreg drill guide I bought for this. Then drilled the correct size and finally chucked the tap in the drill.
Last night I got the first coat of stain on. I'm staining maple which isn't normally a good idea as it can get blotchy and absorb the stain different. I used pre-stain conditioner before I stained it.
It's a bit uneven but I'm not worried about it yet as I still have two coats of a walnut gel stain to put on. Should get that on this week and the top coats depending on how long it takes to dry. I'm following the same steps on a scrap piece of wood so I can test that to make sure it's dry before ruining part of the real piece.
