Yes, I am going to cover everything with doors. The idea is really to keep dust out of everything. I'm building the recessed panel doors next. If I have to dado everything, I'll probably only get 1-2 doors a day done for the next week or two.Are you planning any doors for the cabinets?
I know. That used to drive me nuts when I'd watch Trading Spaces and they'd take a nice oak furnature piece and paint itLike the cabinets, but why use a nice hard wood and then cover it up with paint when you could have used HDF for the majority of the building of them and saved some funds on building them.
I guess I would built the shelves out of wood and the sides from HDF and the tops. Just my $0.02
Yeah I noticed that too. I had a leak and was in a hurry and tossed some kitty litter on the puddle. I never made it back out for a while (like 6 weeks or so...) to clean it up. It's not the epoxy's fault, I just daudled too long in cleaning it upNice work. I am curious. In the photo with the Pontiac on the rack. Has the floor coating worn away underneath the engine area in 6 months or is that just "stuff" on the floor?
Great job. I wish I had the land to build a custom garage. I especially like the tool storage area.
What is the countertop material called? I'm assuming it's some type of rubber?
Just found this tread and read it first to last, very nice work!
If I may and I apoligise if my questions are answered in the posts-
Why did you not put the windows in as/per the concept drawing?
In hind site now, would you make any design changes?
Thou the man door is at the front of the garage which is more accessible from your home, do you think it would be a better entrance by the bench ?
Thanks for your posting, top notch!!!![]()
Boy, talk about like minds. Storage room, ceiling fans, same lift?
Fantastic work!
What material did you use on the counter top?
It's looking 'Oh So Sweet'!
Did you say your wife is helping you paint some doors? ... 'Oh So-o-o-o Sweet'!
Just gotta ask - what are those mags on the lower left cabinet shelves; the ones with the very interesting 'composite' spines?![]()
VXK,
First, I applaud your work again!
In regard to your color choice for the cabinet door faces, the white would keep the light from being 'swallowed up'.
BUT....
Looking at the face of your beverage fridge (brushed SS?), I'd love to see thin sheet inserts like that in both top and bottom cabinets. They would be a striking accent/highlight, easy to clean, light reflecting, and tie-in nicely with the fridge front. If you were able to source thin sheet stock, the wood panels would act as a backing piece to lock each sheet into the face frame. What say you???![]()
It's been so long since I've specced sheet metal, I wonder what a reasonable thickness would be. 28ga? It's just a skin anyway, right.
Edit** Just checked ballpark pricing, 24ga 2x2 section ~$40 each, I'd need 5. Wow!
Wow is right, that is spendy! There may be an alternative metal you might consider which might be a good visual match for the fridge. I just assumed it was a SS facing on it; perhaps not. The material on the face of the doors isn't structural, so even if it was roofing tin, aluminum, galvanized, etc., as long as it has the same look as the fridge door, it could blend nicely. The overall look would be very clean and modern. Just my $0.02.![]()
