mxhonda
This weekend I installed the lighting for my new 30x40x12 metal building. I used my lighting design calculator to determine the type, quantity, and light output in foot candles. After plugging in several different types of fixtures from metal halide high bay, low bay, flourescent industrials, high output, slimline, etc., I finally decided on 8 four lamp 8' flourescent fixtures with 4-32watt t8 lamps per fixture. This gave me the 30+ foot candles of light I was looking for with a very even light (no hot spots) and a very energy efficient package (less than 900watts, 7.5amps total). The lights and lamps cost $400 from the local Home Depot, who had a better price than my local electrical supply house's. I split my circuits to 2 switches so I can only turn on one side or the other if I don't want them all on.
I have attached the 2 lighting sheets that describe the results on paper so you know what to expect before you start, along with layout and dimensions.
If you post on this thread the following info along with what types of lighting your considering, I will print out a report for you to help with your next lighting project. It may take a couple of days turn around depending on my availability.
Required info:
Length, Width, and Height
Roof Slope IE: 3:12 pitch, 12ft sidewall, 16ft peak
Dropped ceiling (tile size) or open ceiling
Relflectance Wall, Ceiling, Floor IE: white walls, silver ceiling, tan floor
Power limitations, desires IE: only 10amps available, 120v/240v, most efficient
Let me know what you expect from the finished product.
"Remember, When designing a new or upgraded lighting system, it is important to avoid under-lighting or over-lighting your space. Although 30 to 50 foot candles of light may be sufficient for most spaces and activities within
a garage, having too much light can be just as fatiguing as having too little. Adding more light than you may need does not necessarily translate into higher quality. Not only does over-lighting waste energy, but it can also reduce lighting quality. Furthermore, there is no sense purchasing more luminaries’ than you may actually need."
Required info:
