Where did you get the graphite electrodes ? Any mess to clean off the object when it comes out like black stuff ? Maybe it's easy to wash off...
Thanks
Graphite is from ebay, a flat rate box of slabs that are about 13x5x1
I drill and tap 1/4 20 holes in the ends and then make setscrews out of SS bolts to screw the pieces together. So the electrodes are about 4 ft long.
Power to the electrodes is a ring terminal with a brass screw going into tapped hole on top of graphite. This connection is above the water line so it does not get corroded.
At one point I upgraded from using a battery charger to using an inverter welder supply. Things went faster, but the heat at the connection to the graphite made little cracks in the graphite. So I made new connection holes and went back to the bat charger.
To support the electrodes I made holders out of pvc pipe. The side of the pipe is cut away in sections, leaving a frame of plastic. The electrode weight is supported from the bottom by sitting on the wall thickness of the pvc. This tank is outside and in the winter I pull out the electrodes so they don't get damaged by the ice when the tank freezes.
Did not want to pull on the wires.
The part being cleaned does come out with black on it. I go after it with the pressure washer but there is some black left.
So there is still work to be done afterwards, but for me it is a good step on the process.
I have 4 electrodes, 1 in each corner of the tank. Even with that I would like some device to rotate the part being cleaned but have been too lazy to do so yet.
Regards,
404
