- Joined
- Nov 4, 2017
- Messages
- 10,461
Little pricey
Blue Point/Snap-on pullers don't hold a candle to the classic Plomb/Proto puller. When a design that simple is around and in use for almost 100 years, and its major competition is a veritable Rube Goldberg contraption you know it is the best.Blue Point pullers are the best ever made in my opinion. Not for $2200 though.
Having owned the Plomb/Proto pullers and Snap on CJ series plus the Blue Point CG series, a puller that holds tension on the jaws was valuable on the 10-20 ton pullers, especially 3 jaw. Blue Points worked the best hands down in my experience. The Proto's had weak screws when a hammer was needed to jar the screw and didn't like a hard pull. The Snap on CJ series jaws were always to thick to fit where I needed a puller an the thin jaws always broke their tips off. I sold the CJ stuff and kept a few smaller Proto pullers because there are times where they fit the specific job better.Blue Point/Snap-on pullers don't hold a candle to the classic Plomb/Proto puller. When a design that simple is around and in use for almost 100 years, and its major competition is a veritable Rube Goldberg contraption you know it is the best.
Right. I saw it/them in the 37 Industrial cat. on the collecting snap-on site on a page headed Snap-On assembly tools. Is there a difference between the 71A and P71? Also that double end in your pic, Ford stamped as well?The P71 (N and 10) are listed in the 38 supplementary cat.
Hi. Sorry. In this particular instance I meant the 71A and the P71. I'm assuming that(71A) is what has been grinded off from the shank of our ratchets that have the P71 stamping.The P71-N has the flat handle, the P71-10 has the round handle. Pic attached is a P71-10 with a 41 code
Ford is stamped on the double end.
I think the difference is just lock button vs ball bearing.Hi. Sorry. In this particular instance I meant the 71A and the P71. I'm assuming that(71A) is what has been grinded off from the shank of our ratchets that have the P71 stamping.
By "A" you mean 71-A and by "N" you mean P-71-N is that right? or are you talking about the later regular 71-N?The A has a pin selector and the N would have a flat selector
Got it. I didn't phrase that right and I deleted it because I can't even understand what I wrote. I just didn't understand why you brought up the "N" selector. But you ( and Oldtule guy)did answer my original question ref. difference between 71"s and P71's....Anyway, my P71A isn't a pin selector, maybe a shop made replacement. Also did you notice besides being female drive the gear on the double seems to be thicker?To make the P , you take a 71A or an 71N then replace the detent ball with a pin. And the P model number is applied. sometimes the old model number is removed. Would like to see a 71N that’s been changed
ORC, the smaller one is an FB-50. I have a couple posted upthread.Here are a pair of hand carry boxes I picked up on an overnight trip to a swap meet in Roseburg yesterday. The larger box is a K-21, probably pre-war. Eagle snap latches and cross dividers on the top drawer. Leather handle is toast but I think I have one to replace it. Paint is black with nothing showing under it. It has a few rust issues and will need a new piano hinge to replace the cobbled door hinges on the front panel. Also the handle is missing from the rust infected top tray.
The other smaller box I'm not sure of. It resembles a K-24 but the dimensions are off. It is 18-1/2" long, 6-3/4" wide, and 4-3/4" tall. Grey color seems original. The cats I looked at show the K-24 at 20" long. It is missing it's tray but the leather handle is semi-ok. I'll probably just clean it up a little for now. The pics. Ed.
Did they use orange paint (where all my neighbors just use real rust) for patina?Looks like someone tried to "age" it but wasn't successful at all. Hopefully I can remove it and save some of the gray paint underneath. I
