HOF
How is this ratchet used with the hole in the handle to do a "Hot Stick"? I thought that "Hot Stick" was a punch stick thing in electrical work. Thanks. Snap-on 1990 Catalog.
Yesterday’s estate sale finds. I thought that the crowsfoot would be an AN marked but it was Snap-on. I assume that indicates that Snap-on was the supplier of the AN crowsfoot military versions. The 1/2” deep socket looks to be early and the other two sockets are Par-X.
I did a comparison of the Snap-on crowsfoot to my AN marked military ones and despite the similarities in design, there are some differences. The date code looks to be 1961.IMG_7680.jpegIMG_7681.jpegIMG_7695.jpegIMG_7696.jpegIMG_7698.jpegIMG_7697.jpeg
Here's a sliding t extension with a lock pin, a1006 and a1003
Steven 33
there were at least two BP 9/32 drivers made. here is one. there was a earlier version with a different handle, but I do not think there is an example that still is intact, as they have disintegrated (there is a pic of one I had on the collectingsnapon site, but it has now disintegrated)
Have you seen any without the different style detent ball? The little notches?Screenshot_20260329_143432_eBay.jpg
The more I look at that ratchet, the more It appears someone cobbled it together. The hammer tip looks an awful lot like the one on the Bog open gear, though the socket is different. When I get around to taking it apart, I’ll have to inspect the gear and see how it works so perfectly, almost like new, if it isn’t from Snap-On!
oscarsnapkin
Found this tool in an old shop. Looks like something for shocks but not sure. Googling the Snap-on number doesn't give results.
Does the body have a hole for a ratchet? I’m wondering if that is just the socket I posted but with a hole drilled through it and a handle added by a previous owner? Look at where the handle goes through the body.
I know the one from the catalog is a socket. I was asking about the one that the user posted that has a handle attached to it. I was wondering if it I simply a modified socket or if it was sold with the handle attached.
Yup, little slow reading the references you quoted. Apologies.
Redraptor
Greenville, PA
Yes. It has a 1/2" drive in the end. Strange and expensive tool for the intended purpose. Thanks for the response.
Two Snap-on finds at yesterday’s estate sale. I was particularly happy to find the 7mm combo as that one was missing from my user box. IMG_7973.jpegIMG_7974.jpeg
The other tool was a 3/8” drive 8mm hex bit. I’m having trouble deciphering the date code. Any opinions?IMG_7975.jpegIMG_7976.jpegIMG_7977.jpeg
It turned out to be a duplicate so it will head to the summer home in a month or so. IMG_7988.jpeg
oscarsnapkin
Just picked up this set of carburetor adjustment gauges. There doesn’t seem to be a date code on them. Anyone have a clue as to when they might have been made or if the ring they are attached to is original?
MR.X
Wondering if anyone knew the story on this socket? Appears to be a standard 15/16" impact P-300-1/2 but has a GM and Ford number on it. Item number comes up as a regular socket in the catalogs.
Standard Power sockets P or PDH sometimes had the GM or Ford equivalent# stamped on them. Maybe they changed the SOP over the years. Is there a date code? ....or maybe I misunderstand the question completely.
snapmom
Florida
yes, quite unusual to see all three model numbers. probably late 30s or to late 40s. power socket, pic is from a 48 industrial cat
Smokeshow69
In the years just after WWII, aluminum was used to make many things that later were made of other materials. The reason for this was that the aircraft production was geared up so high, and the war ended so fast, that there was a lot of unused aluminum sheet left over.
Pretty quickly after VJ Day, military aircraft started being scrapped in large numbers. I have a large farm shed that my grandfather had erected that used the timber frame from a WWII training camp truck shop. It is still covered with the corrugated aluminum roofing from 1953. Made of melted down B-17's and B-24's.
Very cool story. I was just listening to a podcast yesterday that was talking about all the ww2 gliders in crates being scrapped post
War for the value of the wood crates that folks used to build things around their houses/farms. As to your truck shop shed are you referring to Camp Adair?
Snaparxon
Closer to Idaho
Not the best example by any means but a neat S1416W 7/16" - 1/2" wrench. Interesting that there is a "pilot hole in the gullet of each end.
MR.X
In my experience the actual numbers alone are quite a bit less unusual than being labeled ie. "Ford" or "G.M.C" before the numbers as in the OP's example. All these sockets I pulled are stamped with 3 unique ID numbers....not all visible in one pic but they do.
BlakeTheCarGuy
Roanoke Virginia
One of our great forum members here didn’t leave a name or username sent me this vintage Snap-on 3/4 ratchet and a 3/8 T-Handle that says Snap-on Ferret on it. Not sure exactly what that means but it’s quite interesting. I love unexpected surprise packages lol. Someone from Ohio. I can definitely use this. I’ve often found myself grabbing 3/4 to work on dad’s semi truck. And the 3/8 T-Handle is super cool. I believe the T-Handle is dated 1955 and then the ratchet appears to be dated 1951.
img_4549-jpeg.2521872
