JustVicingIt
Quick follow-up to my recent impact socket buy, how would y'all go about degreasing and cleaning them? Soak in simple green, rinse off then soak in oil?
3/8 T-Handle that says Snap-on Ferret on it. Not sure exactly what that means but it’s quite interesting.
The name for their entire 3/8-inch drive line, introduced in 1927, when they had only been making 1/2- and 5/8-inch drive prior. As @TheRealZeus alluded to, the catalogs talk about engines and engine compartments getting smaller, and its sleekness.
Ironically, the subject just came up on a different thread about the Accles & Pollock "Ferret" set, which was made in England decades earlier. I posted more on Snap-on's story for how and why they named it linked there.
oscarsnapkin
One of our great forum members here didn’t leave a name or username sent me this vintage Snap-on 3/4 ratchet and a 3/8 T-Handle that says Snap-on Ferret on it. Not sure exactly what that means but it’s quite interesting. I love unexpected surprise packages lol. Someone from Ohio. I can definitely use this. I’ve often found myself grabbing 3/4 to work on dad’s semi truck. And the 3/8 T-Handle is super cool. I believe the T-Handle is dated 1955 and then the ratchet appears to be dated 1951.
img_4549-jpeg.2521872
That’s one heck of a gift. I have the same ratchet head, but mine appears to be a ‘53. I picked it up dirt cheap about a year ago. I was eventually able to find both the long and short knurled handles on Marketplace. I love using it. They recently started making an 80 tooth version, but I like the look and sound of the old ones. I can’t imagine being in too many tight spaces with a 3/4” ratchet where an 80 tooth would really be much of an advantage. Enjoy.
oscarsnapkin
I picked up this 5/16-3/8 DOE at a sale this week
Looks like the date code is 1968...
Snap On stuff turns up with a fairly high degree of frequency around here
But.....usually one of this, one of that...
Apparently that’s a Bendix brake adjusting wrench. I saw the Sxxxx part# in your photo and figured it was some type of specialty tool, so I googled it.
snapmom
Florida
Just picked up a NOS DMC-110 Aviation ratchet dated 1983 with a Snap-on 11/32 socket attached. Anyone know what the DMC refers to?
HOF
2001ZR2
Kansas City
F-70-M date code
GF-720 date code
Really don't seek out Snap stuff but find it sometimes. Have the rebuild kit for the F-70-M as it was only a dollar at an estate sale. Doesn't work that well it binds up on the loosen setting.
Believe the F-70-M is 1953 but not sure about the GF 720
genog
Silicon Valley
Found another Snap On specialty tool today.....
Very long 17" 5/8" combination wrench, S9465A
Previous owner ground down the box end
Identified as used for Chrysler Fluid Drives
Shown with a regular 5/8 OEX combo wrench
930dreamer
Amarillo,TX and Stinnett,TX
This doesn't have the light and I didn't look at it to see if there was evidence of the electrical plug. K-300, 1941 was the first year and the KR-300 in 1948 looks the same.
Well, it does have the roll down door, not sure if the seller knew that, not bad for $20. Now a SO light!
bmwrd0
Beaver Fever Oregon
Well, someone was in my neck of the woods and didn't say hello!
I was looking at that on FB, but didn't want another toolbox needing paint. Glad someone here bought it.
930dreamer
This will have to wait a while but how is the roll down door removed? Anyone have a light that can post some detailed pictures? Best way to remove a few layers of paint from said door? Thank you!
Steven 33
In my experience the actual numbers alone are quite a bit less unusual than being labeled ie. "Ford" or "G.M.C" before the numbers as in the OP's example. All these sockets I pulled are stamped with 3 unique ID numbers....not all visible in one pic but they do.
Lots of oddballs in the early days. The p series can be found from as early as the late 20s. Here's four different 3/8 sockets. Well 3 different p-120 and a d-120 one of the p-120s appears to have a 31 date code. And the 71A is marked ford and is actually a P71A
Steven 33
S-9044 seems to only show up starting in 39
snapmom
Florida
A sort of odd wrench. Snap/on model A-59484. about 5" long, 9/16 opening. Its hard to date, has no code, does not have Made in USA. Does have a / in the name. So the USA stamp starts in about 37. but there are not to many specials with the Snap on name, until the 40s, usually are Blue Point. The / goes away mostly in the late 40s. Its probably military, but not sure.
Steven 33
