let's see your craftsman block grinders
MPOWERD
Yes it is indeed held by a single screw but it moves around very easily. Shouldn't I add a second screw to hold it in place better, especially how rough the grinder starts up...
exmaxima1
Midwest
I usually stuff a piece of foam tape under the relay to prevent rattles. Also along the edges of the bottom plate where it contacts the base.
bczygan
DETROIT! Arsenal of Scrappers
In Akron OH $85
https://akroncanton.craigslist.org/tls/5219804539.html
torqueman2002
If 'your' screw is loose - add a small amount/lengths of rosin core solder, to the screw's mounting hole, in order to snug up the screw. A larger screw might damage the mounting post.
I have a grinder that the relay's metal mounting tab is bent, keeping it from seating properly. See if your grinder's tab can be tweaked. :thumbup:
808state
Just picked this up for $40. Did I pay too much? Don't see many up for sale locally in Hawaii and I've always wanted to restore one. ImageUploadedByTapatalk1442549019.707735.jpgImageUploadedByTapatalk1442549039.590149.jpg
bulletpruf
San Antonio
BP: if your block is a commercial one you can rewire it for 220. I think the wiring diagram is on this thread or maybe over on the the other forum where Doc posts a lot of them. i'd be curious how a rewired block works on 220 if you do have one that you can try.
congrats on the move and hope the new digs likes having some old US tools in it's garage.
Thanks, Drives. I'll probably keep it at 110 since I'll only be here for a few years.
EDIT - it's a commercial block; if it's easy to change to 220, I'll go with that.
Scott
bulletpruf
San Antonio
Good to hear from you BP, see my comments in Blue.
BP - let me know if the inside bottom cover does not have the wiring diagram. I think I have another 1/2-HP m-397.19591 I can snap a pic of it's wiring diagram.
Doc -
That's the one!
I'm confused on one thing -- if it's a comm'l block, label states 115/230, is it not ready to go on 220/230 right now? If not, I'm assuming it's a simple modification to go to 220. I'll check for the wiring diagram.
Thanks
Scott
torqueman2002
Doc -
That's the one!
Thanks
Scott
I'm glad to hear it has 'caught-up' with you in Italy.
It will need the internal wiring re-arranged (see below diagram) to work on 220/230V. Be sure to verify if your power is 60 cycles, as jakemac mentioned.
:thumbup:
torqueman2002
Speaking of wiring diagrams, the following are posted to PhotoBucket.
115V
3/4-HP m-397.19350
1/2-HP m-397.19430
1/3-HP m-397.19580
1/3-HP m-397.19581
115V 230V
1-HP m-257.191600
1-HP m-257.192190
1/2-HP m-397.19590
1/2-HP m-397.19591
3/4-HP m-397.19440
3/4-HP m-397.19450
3/4-HP m-397.19470
Link --> http://s786.photobucket.com/user/torqueman2002/slideshow/CM%20009%20Wiring%20Schematics
I'll be happy :) to add additional diagrams.
Basically what is needed are high resolution & straight on pictures of the diagram, outside label, and inside wiring (optional).
Please PM me for info. on how to forward pictures for uploading.
Thanks. :thumbup:
808state
808 - I would think that a 1/2-HP for $40, in Hawaii, qualifies for a
you ****!
:thumbup:
Haha! Thanks man. Couldn't believe how in good condition it is. Missing the quench tray and one of the ears on the shield is cracked but that's about it. Any links on how to fix vibration? Not sure if it's the stones causing it.
McBrownie
Cleveland, OH
808,
Try running without the stones. That is an easy way to find out if it is the stones or not.
bagged89s10
CT
I setup one of my grinders as a buffer. It's missing the side guards. Polishes nicely with good compounds. Does anyone know where to find threaded buffer shafts? Or should I just keep it the way I have it?
nine4gmc
Dallas
I just removed the inner guards and used an oversize large nut to space the buffing wheels out towards the ends of the oem shafts for more clearance.
808state
They have replacement quench trays at parts direct.
Sears parts direct? Got a link? First place I looked but shows discontinued for the specific model. Not sure what the substitute would be.
Sorry little slow today. Took the original part number and searched for it and came up with this substitution for a 397.19430 5336943
nine4gmc
Dallas
Did you leave the light on yours?
The one I use for a buffer did not have a light. :(
The link is in this thread somewhere, try doing a thread search for it. :dunno: I'll take a look myself and see too.
nine4gmc
Dallas
I've found about 7 blocks and round tops in the wild but so far, no quench trays... Only a couple had lights but none were restorable due to broken gooseneck or damaged beyond repair reflectors etc. you guys up north are in the hotbed for good condition finds.
Sent from my iThingy using Tapatalk
exmaxima1
Midwest
Line power frequency for Italy is listed as 50 hz, but I don't see how that would be an issue other than reduced rpm. At 50hz the grinder will just spin at 50/60 x 3450, or about 2875 rpm. Since that is a 7-inch grinder, the effective grinding speed (about 5300 ft/min) will be very close to that of a 6-inch grinder running at 60 hz, which is optimum for aluminum oxide wheels on carbon and high-speed steels.
Scimonetti
VT
After looking forever I finally found one!
Pretty dusty but in good shape and only missing a shield. The tag is really weird though, only contains model, serial # and Sears.
What does that mean? Isn't that info necessary for sale?
Anyway, I got it and the cabinet for $15, It runs smooth and I'll bolt it to the cabinet and store my grinding/buffing wheels and organize sandpaper.
jakemac
New England
It means that the grinder spent too much time in the sun. The label has bleached out. The ink for the s/n is different than the ink on the label so it lasts longer.
Great score on a hard to find 3/4hp model. :drool:
harleybuilder
Southern IL
Good find. . The tag is faded out, that's why you're only seeing minimal information on it. I think Torqueman has a file to get a new tag printed.
torqueman2002
Holy molly! Yet another you ****! :lol_hitti
Check my sig line for a link to a file to print a replacement label.
Nice score.
:thumbup:
drivesitfar
SC: nice find and the little cabinet is probably an even better find than the 3/4 block. right place right time and your lucky day. congrats and couldn't have found a better home. cheers
torqueman2002
Maxima - you, of course, are correct.
"It will run 5/6th slower and might tend to run a bit hotter, but the 220V setup will reduce the current and likely offset that heating.
He will need to either use a plug-socket adaptor or put a Euro Style plug on the cord. I'd suggest the plug, so that there is no confusion when he returns the grinder to the US.' - Charlei, OWWM
Thanks Maxima and Charlie!
:thumbup:
Update.
"It is better to operate a 50 Hertz motor on 60 Hertz, then the reverse, but if it's not going to see heavy use it may be OK, and as said by others use a attachment plug to match the local style, Euro cords are brown, blue, and yellow w/ a green stripe,
brown is hot,
blue is neutral,
yellow/green is grounding/ earth." - R Meyers, OWWM
