let's see your craftsman block grinders
WAITS
Alabama
Nice color combination! What brand and color codes?
Titanium should bling it out nicely. :beer:
I don’t remember the code, but from primer to shiner was rust-o. I’ll include the code when I post it ad complete! Man yea, im Sitting on how hot I want my pieces to get, I’m thinking purple!
TM I’ve also got some info to send you soon, about the winding leads!
Here’s a few Ti pieces to pass the time, until the blocks done.
Bisquit cutter
The blue spots in wrapped wire
Plaque for daughters softball coach
Pipeliner hood
Hood, bracelet, and ring set
torqueman2002
Bisquit cutter
Pipeliner hood
Nice work!
:bowdown:
davethorik
Norka, Ohio
Got this for free today. I was told it would hum on startup but wouldn't spin, so the wheels were cannibalized and grinder was sitting out for the trash. Nuts/washers still there.
Model 397.1949
I thought it might be a pre-block, due to the rounded shape, but I'm not sure.
WAITS
Alabama
Model 397.1949
Mannn please open it up and find out what color wire goes to which lead on the motor! I’ve got the same model
exmaxima1
Midwest
Model 397.1949
Pre-block would be cast iron (not aluminum alloy) and weighs about 55 lbs or so.
davethorik
Norka, Ohio
Its hefty but i dont think 55 lbs hefty. I think most of the weight is from the wheel guards. I should get a chance to tear into it this weekend.
lafester
Northern CO
Model 397.1949
Great score for free! Even if it is toast you have at least $100 in parts there.
I got one very similar recently, I'll take a few pics if it helps anyone.
torqueman2002
Anyone now the wiring for a 3971598?
User manual doesn’t have one
Is that the same 1/3-HP Block m-397.19580 you posted in the link below?
https://www.garagejournal.com/forum/showpost.php?p=8402577&postcount=12178
Because I don't recognize the model you posted: '3971598'.
Here's a wiring diagram for 397.19580, as well as others.
:thumbup:
exmaxima1
Midwest
Your grinder is NOT a Pre-Block. In addition to being alloy (and not cast iron), your grinder has a slot for a removable quench tray. Pre-Blocks have their power switch at that location. The switch on a Pre-Block would not fit higher up the center panel because the motor stator (laminations) is gigantic and takes up all the space.
WAITS
Alabama
davethorik
Norka, Ohio
Thanx for clearing that up :thumbup:
I had a few square-top block grinders, but ended up selling them a few yrs ago. One of them had identical wheel guards as this one, or nearly identical as memory serves, with the rest just having the lighter sheet metsl guards. The one with cast wheel guards was noticeably more heavy.
Not long after, since i apparently have a fetish for department store branded bench grinders, I bought 2 almost identical J.C. Penney marked 1/3 hp grinders. They are Baldor relabels, and very good grinders. This block will be in good company.
I have a quench tray for this Craftsman somewhere, but I just moved and have no idea where it's at right now.
bagged89s10
CT
garage clean out on block grinder parts. I have inner guards and housing parts for 6” block. I also have housing parts and one side guard set for a 7” block. I don’t know what’s wrong with the windings in the second to last pic. make me an offer if you need anything. I just want these gone.
torqueman2002
bagged - those are nice looking Block parts. I need to do some spring, winter, summer, fall cleaning, too! :beer:
BTW - Here's a good video about electronics cleaners, ie: Deoxit D5
How to use Electronics Cleaners
bagged89s10
CT
i’m getting ready to build a new garage so I can turn the current garage into a bedroom with 2 more bedrooms above it. the current pandemic is delaying the meeting with my architect though.
But that’s why I’m trying to clean out and organize as much as possible as a lot of the things will have to be put in a storage container during the construction.
Chadwilliam1
Cincinnati
What are my options on the light, is there a replacement cover or replacement light?
Also best way to clean it?
Sent from my SM-G975U using Tapatalk
torqueman2002
Thanks
You may want to replace it, for all the time it will take to repair and clean it.
Bench Grinder Lamp Shade 534497198
$6.25 + shipping
https://www.searspartsdirect.com/product/1c81334m3m-0071-358/id-534497198
I just ordered 2, to have on hand. They were discontinued from another site that carries Block parts.
https://www.ereplacementparts.com/black-cover-p-973653.html?osCsid=28fu83dlsa2d5hfacm7sdc6ri0
Chadwilliam1
Cincinnati
What is the best way to remove the bearing? bcbfb9b5a7cde0144d6b429a54996304.jpg
exmaxima1
Midwest
Should just tap out. Nothing holding it in there.
Sent from my Pixel 3 XL using Tapatalk
+1.
Surprising that the bearing is not stuck to the arbor shaft. I've done maybe a dozen of them, and it's a press fit to the shaft while only a "slip" fit to the housing. The spring washers keep them from spinning in the housing.
Shiftless
East Bay SFO
So is there a purpose to the little hole in the top of the metal reflector?
I have an extra assembly just like that one that Chad posted with the metal flex, socket and head, with good wires (no plastic hood) but I’m staying away from the post office. :(
lafester
Northern CO
Makes me think there is a problem with the arbor shaft.
Hopefully it just got hung up in the housing with old grease.
+1.
bagged89s10
CT
