JoCoSawdust
Nice job Knive!
I just got one! I’ve been wanting one of these for a long time. Anyone have an extra shield or lamp shield?
Why you selling Bags? I'm picking up my first 1HP this Saturday, pretty excited
Sent from my Moto G (5) Plus using Tapatalk
I'm impressed RP! nice work! Did you use heat to make the bends, or do you have benders/brake for that heavy of material?
Sears Roebuck bench grinder 1/2 hp, worth $50?
That's my target price - $10 per 0.10-HP, deduct for broken/missing parts add for location/location/location.Sears Roebuck bench grinder 1/2 hp, worth $50?
Reverse,
Nice job on the adapter. What do you have planned for 1h.p. block grinders #5&6?? I am sure you have a lead on them by now lol.
I used this grinder regularly in the mid to late 70s, including rebuilding my first non-hand-me-down motorcycle and car. When my father passed and Mom moved back to AZ I inherited the grinder, but by then it was in really bad shape. Once I had a garage of my own I intended to buy a new grinder so the old one went into the remodel trash heap I had amassed in the side yard. After some financial troubles I decided to try resurrecting the old one in spite of the heavy use and sitting outdoors for many years and performed a complete restoration. Most of the side plate screws were gone, the clear shields were unusable, and the flex shaft was corroded, but I found enough matching screws in my parts, abandoned the shields, and once I got the grinder running again I was able to clean up the flex shaft and replaced the socket. Fortunately the hood was intact and only needed a light sanding and paint. I chose the red color to match my other Craftsman tools (RIP Craftsman) and thought black would be a nice contrast. I've gotten many years of use since the restoration, to the point it's due for a refresh on the paint and a new set of wheels. I'll keep the red, but am considering a black or charcoal hammer finish for the main body.
Finally got around to setting up the Multitool attachment. Also drilled and tapped the guards on the grinder for the tool rests that I made.
This grinder had a deluxe base at one time. As the guards were never drilled and tapped for rests.
This is the first belt grinder I have had that has a light. I am really liking it.
As far as the spacer to make the attachment fit this grinder. I had a friend of mine. Waterjet the spacer out of a piece of 1” thick aluminum. I found no need for a 17mm shaft collar. I just used a thick 5/8” washer against the snap ring. I am getting no noticeable runout. Runs like a dream. Really liking this set up.
About that multitool attachment, I have a third grinder I was considering getting rid of, it's a lightweight newer CM. I could see a lot of use out of this attachment, do they need extra power or will the little Craftman be enough? My other two are a CM block and a Baldor but they will stay as they are.
Only a fellow block enthusiast would appreciate this.
This weekend I was at my local ReStore store sorting through a HUGE tray of miscellaneous sockets looking for the few old US made gems that occasionally pop up. On this occasion there were hundred of sockets, but almost all were made in China or Taiwan. I didn't find any diamonds.
However, just when I was about to quit, I noticed a piece of rubber in the middle of all the sockets. I thought... "That looks like like a foot grommet for a block grinder?".
I asked the counter lady how much she wanted for it. She said: "Just take it - you can have it for free." I gave her a quarter and left. When I got home, I compared it to one of my Craftsman block feet. Sure enough, it was an exact match.
Figure the odds huh?
Please take a look at this and tell me if it's worth buying for about $30, it's missing most of it's removable parts. Seller says works and that it's 1/2 HP.
I wouldn't mind working on it if it's possible to find the missing parts.
What say you all?
I agree.Depends on your local market. Around here you could find a whole one for $40-$50 ...
What say you all?
What say you all?
My most recent. The original label was trashed so I improvised. Then again I don't really do resto's. I just do refurb's.
View media item 95255
View media item 95256
