Lets see your motorcycle lifts!
sbhockey
Chattanooga, TN
Not mine, taken from another site.
Anymore info on this one? Looks like an ATV lift stretched into a table.
k-os
WI
Do you know the name of the manufacnturer of this lift? I got one used and it doesn't have any markings on it
I believe that is the lift that Princess Auto sells. Pretty much the same as the HF Lift.
jsaw
Geneva, N.Y.
Here is one I built
Not Bob
Sacramento Valley
Old K&L I picked up from work for 250.00. Funky clamp, very heavy, and lot's of moving parts.
sbarshie
Saratoga, NY
Here's mine, it's a retrofit U-Haul truck ramp that mounts to my two post car lift. Works great!
Oldbear
Linden, Alberta, Canada
Sure beats sitting on the floor. Just a Princess Auto deluxe - I used the air pump twice - the foot is quicker.
I added rubber footed pegs at the back and a "dock bumper" at the front. Loading a light bike is easy - loading the Wing with me on it caused the front to lift and the whole thing to slide across the shop - then when I got the front tier into the lock - the front end wanted to dip. Not fun with a 700lbs bike. Grip tape up the middle of the ramp as the back tire has spun on its way up... added extra tie-downs and a better wheel chock.
Next mod is a set of extensions for my feet when I load the bike.
Slickster76
Not the greatest pic of the lift, but you can see it's one from HF.
plow
Louisiana
I don't ride, but my automotive lift is closer to the ones made for bikes.
Jack, What is the length of the blades for your Band Saw? I just picked one up on craigslist for 25 bucks. Needs guides, Upper guide holder and blades?
HTGTS350
Mine, chinese cheapo but very handy and in constant use, it came without the front swivel castors so I had to make my own.
gus1962
Canton, Ohio
Is that a 3 wheel craftsman band saw? I'm using Haltbar band saw blades. It wouldn't be hard to find the length they custom make blades. It's an old saw, probably hard to find parts. Check with ereplacementparts or sears for parts.
yhprum
Brisbane Australia
Thanks Sunstation. I am interested in doing something similar. Do you have any other details, what are you using to pump it up?
Nevermind, found it all in your garage build. Nice job BTW!
