The instructions for the mid height frame shows that the end pieces should be on top of the side pieces, mine simply wouldnt go together that way, nothing lined up unless I did it the other way round.
Thank you very much for posting up the pictures and explaining the assembly. I bought the same tool cart earlier this week and finally got around to assembling it last night. Two things you mentioned really helped me out alot:
1. Removing the drawers during assembly. I did it by myself last night and doubt if I would've been able to complete it with the drawers still installed.
2. Mid height frame pieces. After following your advice about switching the pieces around (not following the manual), everything went together very nicely. I don't know if I would've thought about doing that without you pointing that out.
I've read some people had to drill to get holes to line up right, but everything else lined up just fine. I did notice that I have my gas struts installed opposite than you have pictured, but I doubt it'll make a difference.
I'll probably start moving my tools into it a little at a time until I figure out exactly how I want it organized. I'll also pump a little grease into the zerks on the swivel wheels.
I do have a couple questions (for you or anyone else who has this tool cart):
1. Do you find it easier to move around with the swivel wheels near the handle (as the instructions have you do) or would it be easier to have them on the opposite side (like a shopping cart)?
2. How often would you recommend that I grease up the ball bearings?
Thanks again.
